    Feb 2014
    Country
    Hey guys.. i'm been trying for a while to download videos from this web player called MetrixStream on their site there is a link with their video player, let's use it as an example:
    http://www.metrixstream.com/demo
    They say it's totally protected from 99% of all the programs (IDM, WM Recorder etc...) and impossible to download files from their player.
    I tried to catch it using IDM, and it gave me this URL:
    http://cavecreek.metrixserver.com/m/r/stream/c3Vic2NyaWJlcklkPTEyNTI2Nzc0MzQmb2ZmPTM3O...p_0974cad3.xml
    Didn't work, Then i tried to catch it using WM Recorder, and it gave me this URL:
    http://cavecreek.metrixserver.com/m/r/stream/c3Vic2NyaWJlcklkPTEyNTI2Nzc0MzQmb2ZmPTBfM...p_77e01dd4.xml
    But it Still didn't worked at all!
    So guys... do you know any way to download video files from this web player? if possible without any type of conversion? I Would appreciate your help! A LOT! this is driving me crazy! there are some web sites using their player and i can't catch the videos!
  2. TubeDigger can download it in Rec mode
    Feb 2014
    Country
    Is there any conversion in the file using Tubedigger? if there is, is it possible to download the original file using tools like Rtmp dump, if yes... do you know how?
  4. Former Member
    Dec 2007
    Flash Stream Hunter 1.0.14 will detect and download it (as it plays).
    MetrixStream use one time use xml url. Flash Stream Hunter saves through winpcap, without starting any separate new connection, so url is irrelevant.
    Feb 2014
    Country
    Hey! Thank you! Flash Stream Hunter worked fine! i'm going to use it!
    Tube Digger also worked but the version that i had to download simply didn't open some sites... Flash stream Hunter is a lot better for me, thank you!
  6. Does anyone know if there is an equivalent program to Flash Stream Hunter or TubeDigger for Mac?? I'd like to download videos that are playing with MetrixStream Player. I currently rely on Downie for most web videos, but have never been able crack these. An suggestions are welcome.
