  1. looking for AviSynth script close GOP structure in convert file for dvd pal 16.9 this is from dvd lab Click image for larger version
  2. Avisynth doesn't set the GOP structure, the encoder does.
    Oct 2005
    666th portal
    it's fine. ignore the warning and the dvd will work. open gops more efficient and are allowed in the dvd spec.
  4. If you think you might want to edit the converted video again don't use open GOPs. The tiny bit of extra compression they give isn't worth the hassle.
