  1. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    In case anyone is interested, the latest version of AviUtl v1.50 English translated by MaverickTse now supports both import and export of x265 HEVC in both 8 bit and Hi-10 bit flavors. The same goes for x264. You can export as mp4, mkv or x265 stream.
    I tried an export of 720p and got 3.5 fps on my Q9300. I didn't mess with the default settings other than set CRF @ 23. The same clip encoded to x264 yields 18 fps on the same system.
  2. I didn't even know it can IMPORT HEVC video...(not expecting anyone wanting to edit HEVC stuff at this moment)
    Thanks for the info!
    The x264 8/10bpp and x265-8bpp are fine with acceptable encoding speed, but the x265-10bit one sucks.... no more than 8fps on my Core-i7 2600k overclocked to 4GHz when encoding a mere 640x360 short clip (and the quality sucks too).
    For performance gain, user can use the x64-builds of x264 and x265 (the bundled binaries are x86, except x265-10bpp). BUT do not use the VLC builds, as those binaries do not support "stdin".
    The GUI can use x265 v0.7+170 or newer
