Results 1 to 11 of 11
  1. I bought a retail dvd package that includes two DL-dvds that each disc includes 8 episodes each. So here what happens I put my disc in my pioneer 2208 blu-ray drive by the way I'm running windows 7. Anyway when dvdfab checks the disc it only sees the four episodes out of the eight on the disc. I know the disc has eight episodes cause I watched all of them on my dvd player.
    The program only allows me to select the four only to rip. The second disc in the collection does the same thing. I even reverted to a earlier version of DVDFab v8.2.3.0 Qt it does the same thing as the latest DVDFab v9.1.2.8.
    I tried a diff dvd that I have that is also a DVD-DL disc and there was no problems in seeing everything on the disc.
    Can you play all 8 episodes with a player like vlc media player?
  3. Banned
    Freedonia
    You should post the name of the DVDs. Well, unless you don't really want help. Why? It's possible that the DVD was badly authored and knowing what it is might enable somebody to comment on that. You should also tell what country the DVD is from. For example, in the USA the first season of the TV show "The Office" is one one DVD as there were only 6 half hour (really 23 or so minutes) episodes. That DVD is as badly an authored DVD as I have ever seen, with it not being possible through normal methods to rip the 6 episodes into individual ones. It's been quite a while since I worked on it, but I think it ripped into 4 episodes instead of 6 and I had to use a commercial editor to assemble various parts of what ripped into the individual episodes. Really ugly stuff.
  4. Member wulf109's Avatar
    Jul 2002
    Look at the disk in Explorer,do the episodes list as 8 separate ifo's or one large ifo? look at the disk with Ifoedit and see how the episodes are listed.
  5. The New Adventures of Batman (2007) it's a old cartoon from 1977 bought at amazon USA.
    DVD's play fine in VLC. What other rippers should I try if I can't get this to work in DVDFab ? But I would like it to work though in DVDFab. Eight ep each 22mins each. When DVDFab loads up the disc I'll see four 22min chapters/ep and one giant 180mins approx chapter which I assume is the whole eight ep in one chapter. I don't want to rip all eight ep in one big AVI. thanks
  6. Banned
    Freedonia
    That DVD is old enough that it should not be using any of the new anti-copy protection methods. Download DVDDecrypter and read about how to rip in IFO (IFO and NOT ISO - BIG differerence!) mode. IFO mode should let you rip episode by episode. See if DVDDecrypter can get them correctly. DVDDecrypter hasn't been updated in years but it was the best tool I ever used for episode ripping.
    Nov 2003
    West Texas
    Have you tried extracting the episodes with a different decryption program? Like DVDShrink in ReAuthor mode or MakeMKV? Both are free to download and use. MakeMKV would give you .mkv files as output from a DVD, but these can be re-authored to DVD-Video if necessary with no loss of quality.
    If they fail also, that supports the idea that you have a poor quality disc, rather than an inadequacy on the part of DVDFab.
    I might try another drive if available. My Pioneer Blu-ray burner isn't the best reader I have, and yours may not be reading the second layer of this particular disc well, or at all. But I would say this is a very long shot at a solution.
    Oops, a bit late with these suggestions.
  8. okay thanks, will try these ideals when I get home.
  9. Banned
    Freedonia
    Try DVDDecrypter before trying DVDShrink or MakeMKV.
    Guide to ripping in IFO mode (about halfway down):
    http://www.doom9.org/index.html?/dvddec.htm
    Feb 2006
    go into dvdfabs settings and select disable pathplayer. restart dvdfab and try again.
    discs with mulitple episodes like tv series ect work better with pathplayer disabled.
  11. Originally Posted by october262 View Post
    Thats it, it works now. thanks
