Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
  1. Member tmw's Avatar
    Jan 2004
    I'm trying to watch DVD files (ripped discs) on my work laptop. The DVD's I ripped on my home computer, but in hopes of not having to travel with two computers (my work one is required), I want to watch them on my work laptop.
    System is Windows 7, Enterprise. I have no admin rights. I'm using Media Player Classic, because it doesn't require an installer or admin rights to install, and plays DVD's.
    Breaking Bad season 1 is playing fine, except there is no audio. Does anyone have insights into how to make the audio from TV Show DVD files play in media player classic? If there is a different player suggestion, keep in mind I don't have admin rights on the laptop.
    Thanks in advance!
  2. Member DB83's Avatar
    Jul 2007
    Do you have any sound ?
    No sound could be...
    1. Missing codec/filter. Try installing ffdshow
    2. Sound chip could have been disabled in bios simply to prevent employees using work equipment for pleasure (just a thought)
  3. Member tmw's Avatar
    Jan 2004
    I have sound in general, e.g. youtube videos and dings from emails / IM. Windows Media Player (the built-in program) has sound too.
    Also, I later noticed that it appears the video is running at 1.5x or 2x normal speed. Not sure why that is happening, or if it could be related.
  4. Member tmw's Avatar
    Jan 2004
    Media Player Classic. The other MPC options both require admin rights to install.
  5. Use the portable version of MPCHC (no installation required, just extract the archive and run the exe). It has all the codecs you're likely to need built in.
  6. Member tmw's Avatar
    Jan 2004
    Works perfectly. Thank you!
