Results 1 to 11 of 11
  1. Hello,
    Looking to buy a camcorder that records AVCHD 1080i50 video and want to edit with the simple Imovie. I then want my end product to be rendered on a DVD and played back on a TV.
    Will there be any limitations?
    Thank you.
  2. I doubt that iMovie can offer full-range AVCHD 1080i50 media import capabilities (from all popular brands of camcorders) to the library. Just double check the specs.
    I never had a problem for importing SONY AVCHD Cam footage to iMovie media library, but with CANON AVCHD I remember that I had to convert it to AIC/MOV. I do not have latest version of iMovie.
  3. iMovie seems to be capable of AVCHD files but its the 'interlacing' that its not able to handle, thus it becomes de-interlaced 25P. I may need to purchase Final Cut Pro X. On a side note, do some DVDs support 1080i50?
  4. Banned
    New York, US
    No.
    http://www.videohelp.com/dvd#tech
  5. DVD players don't support HD video at all. Not 1080i, not 1080p, not 720p, nothing.
  6. Thank you all in advanced.
  7. If I end up shooting 1080i50, then want to output to a PAL DVD, what steps do I have to do, to down-convert? Will this then result in "bad" motion?
    Thank you.
  8. Originally Posted by VideoPlayout11 View Post
    If you use imovie and single rate deinterlace, yes the resultant 25p PAL DVD will have worse motion (1/2 the motion samples as an interlaced PAL DVD)
  9. If you use imovie and single rate deinterlace, yes the resultant 25p PAL DVD will have worse motion (1/2 the motion samples as an interlaced PAL DVD)
    What if I was to use Final Cut Pro X?
  10. hello, some resume:
    […]Will there be any limitations?
    about editing:
    - FCP (old versions or X) handles interlaced contents
    - legacy softs: iMovieHD (version 6) and FinalCutExpress too
    all newest versions of iMovie are buggy with these files (they damage them by removing half of their initial informations = deinterlace)
    so you need an editing software compliant with your rushes.
    about broadcasting:
    - iDVD (and most of others softs) deinterlace your video (while converting to DVD: 1080i50 -> 576p25)
    Now the good question is what is your choice. Your input video is far more detailled than the resulting DVD, so:
    - you can choose to obtain a better image (visible when you suspend the playback) = a deinterlaced video (DVD=576p25)
    - or you can choose to preserve fluidity (motion) but obtained a less detailed image = an interlaced video (DVD=576i50)
    No choice is perfect, personally when I convert my 1080i50 editings to DVD, I keep interlacing (I'm an human, not a steady cam , I prefer the fluidity for my own make videos)
    But when I convert some movies (e.g.: for my children DVD-Player) I remove interlacing (useless) -> I obtain a 576p25
    Advertising: my app has a preference to keep or remove interlacing when making a DVD from ann HD file. I don't know if other softwares does it, usually they deinterlace (it's easier )
    So there is no perfect choices, just yours…
    bye
    For DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
  11. - or you can choose to preserve fluidity (motion) but obtained a less detailed image = an interlaced video (DVD=576i50)
    I'd prefer to obtain the smoother motion over a less detailed image, its now a matter of the steps to achieve this. (1080i50 ->PAL DVD 576i) I want to make sure that 50i is still intact when down-scaling my footage for DVD.
