  1. Member Ygramul's Avatar
    Jan 2007
    Poland
    I just put together a 12 minute file consisting of clips from multiple sources (original clips were all encoded to WMV with AVS Video Converter) and I have problem with the output file. The border flickers slowly, as seen here (small file):
    http://www.sendspace.com/file/4dcznl
    Actually... not just the borders. Looks like the whole thing kinda shifts up and down for some reason.
    I experimented with various settings in the Adobe Media Encoder, but they were all more or less like this:
    Codec: MainConcept H.264 Video
    TV standard: PAL or NTSC (I don't think that matters, the clip is going to be played on computers exclusively)
    Frame rate: 25 (same as all the clips)
    Field order: none (progressive)
    Profile: main
    Level: 4.0
    Bitrate encoding: VBR, 1 pass (target: 1.5, max: 2.3)
    Multiplexer: MP4
    Other options are unchecked.
    What am I doing wrong?
  2. It looks like it was (poorly) deinterlaced at some point, that might explain some of the issues - but you would expect the border issue alternating on every frame , not "slowly" like this
    What does it look like before AVS video converter ?
    What does it look like after AVS video converter ?
    What does it look like in PP ? Does issue occur there before AME ?
    What were the PP sequence settings ?
    What were the clip interpretation settings ?
    There are some duplicates, possibly from encoding it at 25fps if this was a 24p clip
  3. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    It's jumping every second of time. Eight seconds = eight jumps.
  4. Member Ygramul's Avatar
    Jan 2007
    Poland
    The source was a decent BRrip (over 3GB). There were no problems with that file.
    The quality is slightly lower, but there are no visible issues.
    No issues in the preview window (AKA program monitor).
    Screenshot: http://www.ultraimg.com/images/FoUI1.jpg
    Where do I find those?
  5. Right click the clip in the clip bin, and you can interpret the file. For example, if it "thinks" the clip is interlaced , you could interpret it as progressive
    Your render settings are progressive, but your sequence is interlaced lower field first. Change the sequence to progressive (no fields)
  6. Member Ygramul's Avatar
    Jan 2007
    Poland
    Right. I must've missed that. I'll try that.
  7. Member Ygramul's Avatar
    Jan 2007
    Poland
    All right! Changing the redering settings of the sequence worked. I made a new sequence after that change and just copied everything from the old one.
