Results 1 to 30 of 50
  1. Member Kivlov's Avatar
    Feb 2014
    France
    Hello world
    to begin, sorry for my poor english, I hope you will understand me
    so, I bought an Imagevue gallery to share private medias with my family. Imagevue can display pictures and videos (FLV and MP4), this is why I chose it.
    I have a Nokia N8 for some years, and I took some videos with it. those are MP4 native, with h.264 and AAC LC. all of them works perfectly with VLC, and I uploaded some of them on youtube without any problem.
    but last weekend, I uploaded one N8 video on my FTP where the new Imagevue gallery is. I tried to play the video before upload the others... the player loaded the whole file before playing it. for a very small video, it's not a problem, but for 100 or 200Mo videos, it's not acceptable.
    so I found some forums where people talked about this : the header must be moved at the beginning of the file. so I did it, with MP4 FastStart, to test. but the result was strange... the video display a frozen image, then load a little and play at the same time, but always frozen... for begin next to the end, a shorter video.
    so I tried tons of software, YAMB for example, or MP4 Box with some GUI, etc... I tried several options that I didn't know but seem to be fine, without any good results.
    I don't have any idea anymore, and I'm not a specialist... that's why I'm here !
    to show you how it works, I uploaded a test gallery with 6 videos : 1 original test from my Nokia N8 (test_original.mp4) and 5 remuxed files, named with what I did on it (for example, test_faststart.mp4 is the one I tried with MP4 Fast Start).
    here is the test gallery : http://www.oxydium.com/test/
    the original video can be download here : http://www.oxydium.com/test/test_original.mp4 (if someone wants to try ^^).
    if you have an idea, I hear you !
    Thank you,
    Kivlov.
    pwet.
  2. The term you are looking for is progressive streaming,
    mp4box is muxing mp4 with this feature set default, I do this all the time, but I use command line. But mp4box is just a muxer, not encoder.
    For example if you get mp4 video from Avidemux it is not ready for progressive streaming, you'd have to run it through Data Go Round utility mp4faststart (I manualy set correct hyperlink here, because yours leads just to mp4box download)
    anyway that Data Go Round neat little program works also, so not sure where is the problem.
    But kivlov has already used mp4faststart .
    Yep, the mp4faststart/hint files freezes a bit at start. Compared to the original that must load entire but then plays ok.
    Have you tried reconvert one mp4 with for example handbrake. Does same problem occur? Just to test.
  4. Member Kivlov's Avatar
    Feb 2014
    France
    but then plays ok.
    not really, when it freezes at the beginning, the video total time is cut : total time - freeze time = video time cut, I lost about 5 or 6s at the first play (15% of the total time in my example !), depend of the freeze time :/
    I tried to reconvert with SUPER, but there were no difference (stream copy). I didn't try handbrake, I will this evening...
    and if someone could try my test video on his own server with his own player, to see if there is a difference...
    thank you
    Kivlov.
    pwet.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    "Stream copy" just copies the video. Reconvert the clip instead. Just to see how it works on your server.
    I can test the file on my server....if I get some free time over.
  6. Member Kivlov's Avatar
    Feb 2014
    France
    I didn't do it, to preserve the quality (and I don't see why it could be different). but I will try.
    pwet.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    http://www.oxydium.com/test/test_original.mp4 plays better directly in chrome and firefox. Without any flash player but just with the browser/html5 player.
  8. Member Kivlov's Avatar
    Feb 2014
    France
    yes, I know that. I tried a standalone HTML5 player, and it works fine. but I have the same problem with jw player and jplayer (standalone), and the Imagevue player is the only solution I should use for security reasons.
    an Imagevue demo gallery has some MP4 videos which work perfectly : http://imagevuex.com/demo/x2/#/various/video/.
    I downloaded one of them, pixels.mp4, and uploaded it on my test gallery. It works perfectly too ! you can try it, it's the first one in my folder. that's why I say that the Imagevue player should work with my videos. but I don't understand what is different between this video and mine...
    pwet.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep. It works fine.
    Something is wrong with the nokia video. And you seem to have tried all remuxers(no video reconversion).
  10. Member Kivlov's Avatar
    Feb 2014
    France
    yes, and my question is : what is wrong ?
    pwet.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    The video is wrong.
    Adding the mediainfo report
    General
    Complete name                            : E:\Downloads\test_original.mp4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42
    File size                                : 51.0 MiB
    Duration                                 : 40s 626ms
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 10.5 Mbps
    Encoded date                             : UTC 2014-02-10 19:06:46
    Tagged date                              : UTC 2014-02-10 19:06:46
    Video
    Format profile                           : Baseline@L3.1
    Format settings, CABAC                   : No
    Format settings, ReFrames                : 1 frame
    Format settings, GOP                     : M=1, N=30
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate mode                            : Constant
    Bit rate                                 : 10.4 Mbps
    Nominal bit rate                         : 14.0 Mbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Variable
    Frame rate                               : 30.000 fps
    Minimum frame rate                       : 29.970 fps
    Maximum frame rate                       : 30.030 fps
    Bits/(Pixel*Frame)                       : 0.375
    Stream size                              : 50.2 MiB (98%)
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 40s 384ms
    Bit rate                                 : 160 Kbps
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Stream size                              : 789 KiB (2%)
  12. Member Kivlov's Avatar
    Feb 2014
    France
    mmm... yes. and my new question is : what is wrong in the Nokia N8 video which disturb a progressive play ?
    pwet.
  13. Remuxing nokia-n8.mp4 back to remuxed.mp4 might help, as it seems like issue is related with mov atoms or web-optimization.
  14. Member Kivlov's Avatar
    Feb 2014
    France
    already did it, with YAMB. didn't work.
    pwet.
  15. might be YAMB issue, try using latest version of GPAC.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Try latest mp4box build. http://gpac.wp.mines-telecom.fr/downloads/gpac-nightly-builds/
    From the command prompt type
    mp4box -hint video.mp4
  17. Member Kivlov's Avatar
    Feb 2014
    France
    ok, I'll try this evening, after work. I don't really see what could be different, but I'll try
    pwet.
  18. Baldrick,
    OP Kivlov is already hinted, I mean he got the hint already.
  19. I'm a MEGA Super Moderator Baldrick's Avatar
    But not latest mp4box build.
    Maybe also set the frame rate to exactly 30fps. But I'm not any mp4box command line expert....so I leave that to enim.
  20. I'm a MEGA Super Moderator Baldrick's Avatar
    okey. I made some tests with latest mp4box.
    One with just -hint
    One with extracting streams then remuxing with 30fps and hint
  21. Member Kivlov's Avatar
    Feb 2014
    France
    thank you Baldrick, I'll test those files... as soon as my web hoster will be back online
    pwet.
  22. Member Kivlov's Avatar
    Feb 2014
    France
    the both videos are online, I uploaded them. but the problem is the same, as you can see
    pwet.
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    I give up then. .
    Get a bettera camera.
  24. Member Kivlov's Avatar
    Feb 2014
    France
    I have another camera since christmas. but I can't film the past with it
    I'm sure there is a solution... but I don't know it
    pwet.
  25. I'm a MEGA Super Moderator Baldrick's Avatar
    Get a time machine.
    Or just try and reconvert. It might be worth it even if you lose some quality.
  26. Member Kivlov's Avatar
    Feb 2014
    France
    yes, I'll try this when I'll come back home. I hope it will solve the problem !
    I'll try Handbrake, with basic options.
    pwet.
  27. Or just try and reconvert. It might be worth it even if you lose some quality.
    Baldrick already said that. If nothing works, Try re-encoding.
    As OP mentioned Handbrake, I was trying to figure out appropriate profile or settings by reading wiki/manual,
    here : https://trac.handbrake.fr/wiki/BuiltInPresets
    Following setting is mentioned for Android Tablet which should also work for you,
    ./HandBrakeCLI -i DVD -o ~/Movies/movie.mp4 -e x264 -q 22.0 -r 30 --pfr -a 1 -E faac -B 128 -6 dpl2 -R Auto -D 0.0 --audio-copy-mask aac,ac3,dtshd,dts,mp3 --audio-fallback ffac3 -f mp4 -X 1280 -Y 720 --loose-anamorphic --modulus 2 --x264-preset medium --h264-profile main --h264-level 3.1
    I am still wondering, How does Hanbrake sets proper aspect ratio? May be it has some some internal mechanism.
    I had a DVR which used to record in mpeg-2 format in such a way that players start freezing and no other software can import it straight without re-encoding,
  28. I tested that remuxed file by Baldrick and it works with jwplayer, ....., that video has just insane bitrate for streaming standards, 10Mbits and great deal even 15Mbit, so it takes a while until it fills buffer , that depends on your download speed and whatever that server of yours is capable to stream, and only then it starts to stream.
    That buffering could go on for a couple of seconds maybe even ten seconds or so, then it becomes a classic, a cat and mouse streaming game, playback catches limit whatever was downloaded and it starts to buffer for a while, until there is enough in buffer it starts to play again.
    In any case using jwplayer, video started to play before the whole video was downloaded.
  29. Member Kivlov's Avatar
    Feb 2014
    France
    so, I tried Handbrake with my video, with the profile enim said. here is the media info :
    General
    Complete name                            : C:\Users\Kivlov\Videos\test_handbrake.mp4
    Codec ID                                 : mp42
    File size                                : 11.8 MiB
    Duration                                 : 40s 633ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 443 Kbps
    Encoded date                             : UTC 2014-02-11 18:32:59
    Tagged date                              : UTC 2014-02-11 18:34:51
    Writing application                      : HandBrake 0.9.9 2013052900
    Video
    Format profile                           : Main@L3.1
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : avc1
    Bit rate                                 : 2 311 Kbps
    Height                                   : 720 pixels
    Original display aspect ratio            : 16:9
    Frame rate mode                          : Constant
    Bits/(Pixel*Frame)                       : 0.084
    Stream size                              : 11.2 MiB (95%)
    Writing library                          : x264 core 130 r2273 b3065e6
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Tagged date                              : UTC 2014-02-11 18:34:50
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 40s 405ms
    Bit rate mode                            : Variable
    Bit rate                                 : 128 Kbps
    Maximum bit rate                         : 150 Kbps
    Stream size                              : 631 KiB (5%)
    aaand, no. play faster, but always a little freeze which cut a little the video at the first play. I tried some other profils and other options, but nothing better than this profile.
    pwet.
  30. Member Kivlov's Avatar
    Feb 2014
    France
    @_Al_ : what is the streaming standards bitrate ? it could be the solution to my problem. cause the videos which works fine have less than 1Mbps bitrate. that's why the last test, with handbrake (named test_handbrake.mp4) works faster than the others ?
    pwet.
