    Dec 2002
    I use MULTIQUENCE to edit my audio tracks as its easy to use for a lamen like me, but I have a track thats weighted in terms of volume to the L/H channel and id like to centre it so it plays equally between the two. I would also like to edit the sound, ie give the track more bass and treble etc etc,
    I cant seem to get MULITQUENCE to do this, so can anyone recommend an easy to use program that can do this......I emphasise the word EASY as I am no expert with these things
    Mar 2008
    I don't use the editor you're talking about, but the functionality you mentioned
    seem pretty basic to all audio editors. Perhaps you should try Audacity.
    Dec 2002
    I have used Audacity in the past for editing , not as easy to use as Multiquence but its so much better, and its sorted my problem out too, Thanks for the info!!!!
