    Nov 2006
    Denmark
    Hey guys.
    I was wondering if you could help me with a problem.
    I would like to change a audio track of a german hdtv capture with a R1 dvd track.
    Now, the weird part is that both are 23.976 in framerate,but the runtimes are different.
    the video have a runtime of 41:25 and the audio a runtime of 42:46, i have watched both videos and nothing seems to be missing, but i cannot get the audio to sync.
    Anyone know how i can make this work?
    USA
    You could drop the audio into Audacity and under 'Effect' select 'Change Tempo' and set the length to 41.25. (2475 seconds) That should make the audio the same length as the video. This may not fix the sync problem, but it may be worth a try.
  3. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Is it possible that one or the other might have 'Dead Audio' for a couple seconds. It would still play ok depending on its audio delay, etc. settings but not once its transferred. Otherwise, redwudz has the best idea.
