Results 1 to 13 of 13
  1. I have a lot of AVI files that have resolution of 512x384, but aren't displayed with 4:3 aspect ratio, unless I force it in a player.
    Can it be fixed without re-encoding the file?
  2. Member DB83's Avatar
    Jul 2007
    Then your player settings are wrong.
    What player do you use and what are your settings ?
  3. What is the player you're using?
    What aspect are they being shown in?
    Can you post the details from the avi. Use mediainfo, view->text.
  5. I have located the problem:
    DisplayAspectRatio/String : 1.391
    4 divided by 3 is 1.333...., not 1.391.
    However, I still don't know how to fix it.
    General
    CompleteName                             : G:\Work\Conversion\SpongeBob SquarePants\2 - Finalization\1 - Episodes\034a - Welcome to the Chum Bucket.avi
    Format                                   : AVI
    Format/Info                              : Audio Video Interleave
    FileSize/String                          : 83.3 MiB
    Duration/String                          : 11mn 8s
    OverallBitRate/String                    : 1 046 Kbps
    Encoded_Application                      : Lavf52.39.0
    Video
    ID/String                                : 0
    Format_Profile                           : Baseline@L2.1
    Format_Settings_CABAC/String             : No
    Format_Settings_RefFrames/String         : 1 frame
    CodecID                                  : H264
    BitRate/String                           : 900 Kbps
    Width/String                             : 512 pixels
    Height/String                            : 384 pixels
    FrameRate/String                         : 23.976 fps
    ColorSpace                               : YUV
    ChromaSubsampling                        : 4:2:0
    BitDepth/String                          : 8 bits
    ScanType/String                          : Progressive
    Bits-(Pixel*Frame)                       : 0.191
    StreamSize/String                        : 72.1 MiB (87%)
    Encoded_Library/String                   : x264 core 77
    Encoded_Library_Settings                 : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0x1:0 / me=dia / subme=8 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=0 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=2 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=900 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
    Audio
    ID/String                                : 1
    Format                                   : MPEG Audio
    Format_Version                           : Version 1
    Format_Profile                           : Layer 3
    Format_Settings_Mode                     : Joint stereo
    Format_Settings_ModeExtension            : MS Stereo
    CodecID                                  : 55
    CodecID/Hint                             : MP3
    BitRate_Mode/String                      : Constant
    BitRate/String                           : 128 Kbps
    Channel(s)/String                        : 2 channels
    SamplingRate/String                      : 44.1 KHz
    Compression_Mode/String                  : Lossy
    StreamSize/String                        : 10.2 MiB (12%)
    Alignment/String                         : Aligned on interleaves
    Interleave_Duration/String               : 26 ms (0.63 video frame)
    Interleave_Preload/String                : 52 ms
  6. I have found a program called mkvmerge, it can change the aspect ratio without re-encoding, but it turns file into mkv.
    I am fine with that, but when I put it in mediainfo, it says that display aspect ratio is 4:3 and orginal display aspect ratio 1.391.
    Can this cause mkv file to be displayed in 1.391 instead of 4:3 aspect ratio when played in some media players?
  7. Member DB83's Avatar
    Jul 2007
    Are you so sure that the correct AR is not this odd 1.391 ? Noone's maths is that bad !!!!
    There is, after all, only a minor difference between 1.391 and 1.333.
    The player should respect the AR flag ie 4:3 but you still have to ensure that your player's settings are correct.
    Also try mp4box to create a .mp4 instead of a .mkv
  8. Originally Posted by AW10 View Post
    All software players will acknowledge the DAR flag in MKV; I have yet to see one that doesn't
    If you want to keep it as AVI , you can use h264ARM
    http://forum.gleitz.info/showthread.php?39549-Tool-H-264-Aspect-Ratio-Modifier
    or this modified ffmpeg build
    http://forum.doom9.org/showthread.php?t=152419
    There is less support for h.264 in AVI , than there is for MKV (h264 in AVI is incompatible with some hardware players)
  9. Thank you all for your help, I have solved my problem.
  10. someone here posted a small utility here on videohelp, author claimed it is clean.
    anyway your problem is already solved.
  11. someone here posted a small utility here on videohelp, author claimed it is clean.
  12. Member DB83's Avatar
    Jul 2007
    Whilst I am glad to read that you have solved your problem, these topics also exist so that others who follow can read them and if they have a similar issue can also solve theirs.
    So it is a matter of common courtesy to state how you solved your problem. Whether it was by a suggestion from a reply or by other means.
  13. Originally Posted by DB83 View Post
    I have used h264ARM poisondeathray suggested and it has worked, but player (MPC-HC) first loads original apect ratio and then changes to the new one.
    What is causing this is that program adds new aspect ratio to additional "original display aspact ratio" tag instead of what players loads first "display aspact ratio" tag.
    Poisondeathray have also said that H264 in avi is not that supported as H264 in mkv. For that reason and the reason above, I have decided to use mkvmerge and create MKV file.
    I have also used a cmd command for creating mkvs (.bat file doesn't work for some reason):
    "mkvmerge.exe" -o "output.mkv" "--forced-track" "0:no" "--aspect-ratio" "0:4:3" "--forced-track" "1:no" "-a" "1" "-d" "0" "-S" "-T" "--no-global-tags" "--no-chapters" "(" "input.avi" ")" "--track-order" "0:0,0:1"
    This works only if all bolded files are in the same folder, if they are not, whole path is needed.
