Ok so first how does it different when select font encoding from ANSI to whatever? For example i have set this t my native language so that regional-specific characters are indeed displayed and not hieroglyphics, but will this mess in any way with displaying correct the english subtitles?
Also why is it that on High Definition files character size appearssmall and i have to up the size from 18 to 22? Can this someho be automated, so i dont have to manually intervene and have it interchange automatically when detecting SD or HD content?
Results 1 to 1 of 1
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 13:14 -
Subtitle Database MPC-HC
By therock003 in forum Software PlayingReplies: 0Last Post: 29th Mar 2013, 03:49 -
MPC-HC subtitle problem.
By Frostheat_22 in forum SubtitleReplies: 7Last Post: 19th Feb 2013, 12:07 -
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 00:48 -
MPC-HC subtitle default
By cheerful in forum Software PlayingReplies: 0Last Post: 30th Oct 2010, 14:27
