Hi everybody,
i've already posted a thread about uprezing to prores, but what finally worked pretty fine with a file, didn't work with another one.
Here's the deal.
source specs:
Video : 00:03:55,880, 25,000 ips interlaced, 1440x1080x12, MPEG-2
Audio : 00:03:55,880, 48*000 Hz; Stéréo, MPEG Layer 2
output specs:
video: Apple PRO RES 422HQ 1920x1080 ~220 Mb/s, 25 fps, YUV colorspace
audio: mp2, 48 kHz, 16 bits, 384 kb/s, 2 channels (stereo)
ffmbc -i input.m2t -vcodec prores -qscale 1 -r 25 -acodec mp2 -sample_fmt s16 -ar 48000 -ab 384k -ac 2 -vf scale=1920:1080 output.mov
I never get a bitrate up to 150 mb (minimum bitrateso the video is accpted by my uplaod system).
can anyone help me with this one.
I don't really understand what makes a video conversion go fine with one and bad with another.
Thanks in advance
Vincent
The resultant bitrate is determined by the source content complexity. For example, if it was still image, the bitrate might be 50Mb/s . If there was lots of action and noise it might be 350Mb/s
You probably don't have enough real details or content complexity (motion, noise, details) in the source video - and have saturated the encoder
The solution is to add a bit of grain or noise -
I'll search the web anyway, but is there a better command to put noise in an image.
thanks in advance
Vincent -
Also, if that is an interlaced source (looks like "PAL" spec HDV ? ), you need to add "-tff" to the commandline
I don't know if ffmbc/ffmpeg has a noise generator offhand, but you can use some filters in avisynth
EDIT: looks like ffmpeg has an add noise filter
http://www.ffmpeg.org/ffmpeg-filters.html#noise -
Well thank you poisondeathray I'm gonna check that;
The point is the video is Black and White that's perhaps the reason why i get a low bitrate
Thanks you a lot
mpeg to prores 422 HQ Itunes spec with ffmpeg
By vinbel in forum ffmpegX general discussionReplies: 21Last Post: 29th Jan 2014, 04:07 -
Convert ProRes to H.264 on a PC?
By madmartian in forum Video ConversionReplies: 13Last Post: 5th Oct 2013, 07:57 -
Encoding to ProRes
By colbster in forum ffmpegX general discussionReplies: 3Last Post: 29th May 2012, 15:29 -
FFMPEG Prores Encoder?
By Guiboche in forum Video ConversionReplies: 19Last Post: 11th May 2012, 17:40 -
Best way to convert ProRes into a format for Handbrake input?
By bugeyes in forum Video ConversionReplies: 0Last Post: 6th Jul 2011, 14:26
