Hi all,
This maybe easy and I just haven't spotted the relevant area within Popcorn, but I was wondering - can I set Popcorn so that it will extract and convert an audio track(say FLAC to AC3) from an MV file, but not to remux it back with the video file?
For my use, I need to mux again anyway.
Thanks in advance. No biggie, but it would be handy if possible.
Are you referring to a MKV file? Popcorn Audio convert doesn't re-encode the video only the audio and puts the new audio within the original MKV container. I have found a way of doing it which is quicker than the Popcorn audio converter by extracting the original audio using MKVextractGUI (found in MKVToolkit) then using Pazera Free Audio Extractor to do the conversion from whatever to AC3 and then using MKVmergeGui to put the audio back with the video!!! Lots of steps I know but it works a lot quicker on my system, otherwise just use Popcorn audio converter and make a cup of coffee or feed the chooks!
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thank you netmask56 - yes of course it's only the audio that is re-encoded. Being an audio converter!
Anyway - thank you very, VERY much for pointing me in the direction of Pazera audio converter - it's brilliant - does exactly what I require. The application perfectly encodes from DTS 1509 to AC3 640 - really, really quickly - and doesn't mux it back with the video, which is what I wanted.
You probably already know this, but there's no need to extract the audio from the mkv - Pazera will take it out of the mkv for you.
Why I need and love it so much, is because I do a lot of taking an audio file from one mkv container, and mux it with an video file from another mkv. So this is perfectamundo!
Thanks again - belatedly!
Popcorn Audio Converter is Backdoor Trojan...
By snadge in forum Video ConversionReplies: 3Last Post: 24th Nov 2015, 09:52 -
PopCorn MKV Audio Converter
By cata1569 in forum Blu-ray RippingReplies: 5Last Post: 5th Jan 2014, 14:29 -
Audio Converter (Popcorn) Problem
By netmask56 in forum AudioReplies: 2Last Post: 4th Nov 2013, 03:08 -
Nightmare with Popcorn audio converter - DTS to AC3
By kevlo in forum AudioReplies: 0Last Post: 1st Jan 2011, 13:23 -
Popcorn Audio Converter Problem
By duracell in forum Newbie / General discussionsReplies: 2Last Post: 8th May 2010, 03:57
