    Mar 2011
    Oregon, US
    What is the best freeware ripper out there? Or the best and cheapest ripper? That coverts the dvd to mkv and mpeg John
    Makemkv. Free in beta mode.
    Aug 2006
    Other options to try are:
    DVDFab HD Decrypter (free) plus VOB2MPG (free) for mpg
    DVDFab HD Decrypter (free) plus Video to Video Converter for mpg or mkv
    Mar 2011
    Oregon, US
    If I put a dvd in the burner , which app do I use to to create mpeg or mkv from whats on the dvd.? John
  5. batch expert Endoro's Avatar
    Dec 2013
    Bozen
    'The Best' program is a program that works. You always need alternatives.
    Aug 2006
    makemkv both decrypts DVDs and creates an mkv on your hard drive.
    DVD Fab HD Decrypter decrypts the DVD and copies the DVD files and folders to your hard drive. The other programs are used to convert the DVD files on the hard drive to mkv or mpg.
    Nov 2003
    West Texas
    Baldrick already told you one good one, in MakeMKV. It will just decrypt and repackage the video, not change the codecs used in the video, nor will it compress anything.
    If you need a much smaller file using H264 in an mkv or an mp4 format, rip to the hard drive with MakeMKV, then re-encode using Vidcoder or Handbrake.
