Results 1 to 27 of 27
  1. Member vhelp's Avatar
    Mar 2001
    New York
    i was wondering if VH put a cap on downloads now. i used to have 117-123KB/sec (and always had this speed the last two or threes now) but this past week aprox 23-38KB/sec transfer speed, or do i have a leach on my DSL. it is only 1 megabits speed. if i have a leach, how do i find out (visually) who is tapped on my dsl ?
    note, as a test, i am currently downloading a file from VH, an avi file and it is 23-38KB/sec, since 3:28pm, 7 minutes to go.
    Nope. It works fine from Sweden anyway.
    But I will check if my host leaseweb has some connection problems.
    Test download this file, http://mirror.nl.leaseweb.net/speedtest/10mb.bin
    It's from same network as this server.
    Same slow speed?
  4. Member vhelp's Avatar
    Mar 2001
    New York
    throughput is 117KB/sec
  5. Member vhelp's Avatar
    Mar 2001
    New York
    if it helps, the file i was d/l'ing from this topic, (there are several clips on there) but i only tested the first clip...if you need me to test again, i could d/l the next clip in that topic.
    http://forum.videohelp.com/threads/361846-Caputuring-VHS-problem?p=2299208#post2299208
  6. Member vhelp's Avatar
    Mar 2001
    New York
    throughput is 23-38KB/sec, 4 minutes to go..
    edit: i corrected a typo in the reported speed. KB not MB.
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I have to ask my network provider.
    Mar 2011
    Nova Scotia, Canada
    Same slow speed?
    According to the graph from System Monitor (Linux Mint) it was between 1.5 and 2Mb/s.
  9. Member vhelp's Avatar
    Mar 2001
    New York
    ok, at least we know the source of the problem. ty.
  10. Member vhelp's Avatar
    Mar 2001
    New York
    i corrected the report speed in post # 7 above. it was KB not MB. hopefully the admin understood i ment KB in that post.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Same slow speed?
    And my file?
    http://www.videohelp.com/download/MPC-HC.1.7.3.x86.exe
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    I understood.
    Do you notice any difference in the speed during the day? Or always similar low speed.
  13. Member vhelp's Avatar
    Mar 2001
    New York
    actually, to be honest, after two years sitting in a closet, i had to take out my new (was then) Dell Inspiron 15R laptop, to test it on my new elgato capture card. didn't know it only works for win7/8 os's. those bastards. very pissed. anyway. it took a long time to install updates (was not aware the darn thing would do that--gotta figure how to shut that off) and that was what tipped me off to dig around. oh yeah, it was happening at work too, now that i think about it. i think we are on 10MBits or something at work. files would d/l at the same 23-38KB/sec. that's been going on for many weeks or longer. i just put it off to thinking that my job was capping our throughput. i guess i was wrong.
    Mar 2011
    Nova Scotia, Canada
    Same slow speed?
    And my file?
    It was harder to tell in this case but it was at least 500Kb/s.
  15. I'm a MEGA Super Moderator Baldrick's Avatar
    Can you try run http://winmtr.net/download-winmtr/
    And type in 85.17.24.140 under Host. Start. Wait until at least 100 packets have been sent. Then send the result to me.
    (My network provider asks for this information, see https://kb.leaseweb.com/display/KB/Making+a+bidirectional+MTR )
  16. Member vhelp's Avatar
    Mar 2001
    New York
    that file http://winmtr.net/download-winmtr/WinMTR-v092.zip the throughput was aprox 50KB/sec.
    did something change in the internet industry ? or is it some sites that have an throughput issue, based on some criteria ?
    anyway, let me run your request...
  17. Member vhelp's Avatar
    Mar 2001
    New York
    i hope this is what you want...i'll send pm.
  18. I'm a MEGA Super Moderator Baldrick's Avatar
    Thanks. Can you try with host: 94.75.223.121 also (it is the leaseweb test server). And pm me the result.
  19. Member vhelp's Avatar
    Mar 2001
    New York
    info sent.
  20. I'm a MEGA Super Moderator Baldrick's Avatar
    THanks.
    Now I'm going to watch the Super Bowl XXXLIIIXIXXIXIIVIVII....and probably fall a sleep before it has started.
    Nov 2005
    speed for me is 38 to 40k...has been for the last few days
    very slow
  22. I'm a MEGA Super Moderator Baldrick's Avatar
    very slow
    Is http://mirror.nl.leaseweb.net/speedtest/10mb.bin faster?
  23. Member
    Nov 2005
    much faster Baldrick....400k plus
  24. Member
    Nov 2005
    do you mean see how fast the page you linked loads? if so it seems faster a bit...the main page when I came in here loaded up just fine
    i just grabbed a random file from the tools section and it started out very slow but by halfway it jumped up to over 600k
  25. Member vhelp's Avatar
    Mar 2001
    New York
    for what its worth, just found another opportunity to d/l something, but from another website, and i'm getting 112KB/sec transfer rate. just in case it helps.
    https://mega.co.nz/#!pVFikRSY!mbbbJb23kfCCPlPiOW0VdQ3vRGtKHD22Pb5gCFPS25s
