Results 1 to 14 of 14
  1. I am a true beginner in video. When I edit my video in premiere it looks ok, but when I transcode it to dvd I get some strange lines left and right of any moving subject in my image. The problem can come from anywhere in my workflow, as I am a true beginner: this is the second video I made in my life. I tried to upload a sample to youtube, but they don't accept the file type.
    Mar 2011
    Nova Scotia, Canada
    Need a lot more info. Post mediainfo output of the file in question, what program you're using to transcode to dvd. It shouldn't be too hard to find out what video format youtube accepts. I very much doubt that would include dvd compatible mpeg2.
  3. It's easy to find out which formats youtube accepts, but my problem is in the file format. In another format it looks fine.
    I transcode with Encore, so it is an Encore document, file extension ncor
    Mar 2008
    Perhaps interlaced video "combing" ?
  5. Thank you Dave, that sounds exactly like what this looks like. I thought of interlacing myself. How do I avoid that?
  6. Banned
    New York, US
    The question we are really asking is what is the format and type of your source video, not your output.
  7. Thank you sanlyn. I am truly a newbie.
    I film with a Nikon D7000 dslr, in pal, 24 fps. Then I import in Premiere Pro; my clips have the file extension mov. I edit things together.
    Then I use Adobe dynamic link to send to Encore. authoring mode: dvd; tv standard: pal; frame rate: 25 (is that a problem when my camera makes frame rate 24?)
    Is that the info you need?
    Mar 2011
    Nova Scotia, Canada
    Originally Posted by Hoser Rob View Post
    .... Post mediainfo output of the file in question...
  9. Sorry Rob, I did not understand that right. I think this is what you are asking for (I don't know how to put it here other than typing it over):
    C\tijdelijk\test video dvd\untitled project\VIDEO_TS\VIDEO DVD Video MPEG-2 Video 2-bit RLE
    C\tijdelijk\test video dvd\untitled project\VIDEO_TS\VIDEO MPEG-PS MPEG-2 Video
    C\tijdelijk\test video dvd\untitled project\VIDEO_TS\VTS_01 DVD Video MPEG-2 Video AC3
    C\tijdelijk\test video dvd\untitled project\VIDEO_TS\VTS_01 MPEG-PS MPEG-2 Video
    DVD Video (menu): 12.0 KiB
    720*576(4:3), at 25.000 fps, MPEG Video (PAL) (Version 2)
    RLE
    Complete name : C:\tijdelijk\test video dvd\Untitled Project\VIDEO_TS\VIDEO_TS.BUP
    Format : DVD Video
    Format profile : Menu
    File size : 12.0 KiB
  10. Banned
    New York, US
    Use the free medaiInfo utility to post information. You can view MediaInfo in "Text" mode. Then that text to your clipboard, and paaste it into a reply.
  11. thank you sanlyn. Then I get this:
    General
    Complete name : C:\tijdelijk\test.ncor
    File size : 13.3 MiB
  12. Does that tell you anything?
  13. Banned
    New York, US
    Here is a sample MediaInfo report on a video that is currently posted in this forum. The "info" the O.P. posted earlier tells us nothing.
    Video
    Format : AVC
    Format profile : High@L3.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 6 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 12s 533ms
    Bit rate mode : Variable
    Bit rate : 5 500 Kbps
    Maximum bit rate : 8 000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Original display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Original frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.530
    Stream size : 7.96 MiB (93%)
    Writing library : x264 core 136
    Encoding settings : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=5500 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=8000 / vbv_bufsize=8000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 12s 544ms
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 392 KiB (4%)
    Default : Yes
    Forced : No
  14. test.ncor is the encore project file
    They meant using mediainfo on the video
    Is this a typo ? 24? PAL would be 25 fps
    What country in Africa do you live in ? (Is the electrical grid 50Hz or 60Hz ) ?
