Results 1 to 16 of 16
  1. Hi. I got this DVD and it needs deinterlacing and restoring, so no matter if I apply srestore with yadif or tdeint in a sample test encode from the source, it gives me good results, no issues and etc.
    But, when I apply the very same .avs to the whole movie and encode, it gives jerky playback with lots of missing frames and at the same time duplicate frames. I just don't get it, I did try encoding various other samples taken from the source and they would give good encodes, but when again applied to the whole source it gives very bad output. I just don't get it why this happens? Why can't it work as it works on samples with the same script?
    LoadPlugin("DGDecode.dll")
    LoadCPlugin("Yadif.dll")
    LoadPlugin("mt_masktools-25.dll")
    Import("Srestore.avsi")
    DGDecode_mpeg2source("test.d2v")
    d = last.bob(-0.2,0.6)
    Yadif(Order=1,Mode=1)
    srestore(frate=24.000,mode=2,dclip=d)
    crop(10, 72, -10, -72)
    Spline36Resize(700,394) # Spline36 (Neutral)
    or same, but with tdeint
    tdeint(mode=1, type=2, link=0, mthreshl=6, mthreshc=6, tryweave=false, full=true, sharp=true, denoise=true)
    Also tried both frate 24 and 23.976
    Even tried QTGMC and like always samples gives good encodes, but when applied to the whole movie it gives same bad missing/duplicate frame jerky encodes with same avs! Also tried encoding from both original vobs or demuxed to .m2v.
    I can upload a sample vob to test, but I don't know how that would help since like I said, encoded samples gives good encodes.
    Total mind*uck!
  2. Describe the source, and how short were your samples?
    Interrupted telicine patterns will often cause this.
  3. It's a NTSC transfer to PAL and is at 25FPS. I tried 1 minute, 3 minute and 15 minute samples. There's 5MB sample, also let me know if you're lucky to get rid of duplicate frames after switching scene without any skipping frames.
  4. Never done one of those, but my understanding is that there are potentially tremendous and possibly non-fixable problems involved.
  5. Add AssumeTFF() before the bob.
    <edit>
    I've seen the video now. A simple srestore() works better than srestore(frate=23.976,mode=2,dclip=d).
  6. Yeah but it works only with samples, I get same issues on trying to encode whole movie. What was AssumeTFF() supposed to do? Didn't help.
  7. Originally Posted by rhaz View Post
    Before seeing the sample I was guessing that AviSynth was defaulting to BFF.
  8. Simple srestore() gave me 11.988 fps.
  9. Did you take out yadif? I meant, just change the srestore line, leave Yadif in. And, of course, you no longer need the d=... line.
  10. Yes, that's what I did. Didn't touch Yadif and removed d= line and left simple srestore() As I remember simple srestore() never worked for me, I always had to set rate.
  11. Originally Posted by rhaz View Post
    Then set the rate to 23.976.
  12. Well yeah, that's what I was doing for last two days.
  13. Without being able to replicate your problem it's hard to diagnose it. So the sample you provided is from a section that's messed up when you encode the entire movie?
  14. Yes, exactly.
  15. If you couldn't replicate the problem from your own sample, what was the purpose of uploading the sample ?
    Try uploading a longer sample , long enough that even you can replicate the problem, and the section cut from your encode where there are problems
    srestore isn't perfect, it - will miss some matches that could have been done manually , and sometimes there are frames for which there are no solution
    But from your description it sounds like it's failing miserably ?
  16. Well. Good news. Have no idea what was the issue, but I made it. I encoded the movie in two parts by trimming it in half using this:
    srestore(frate=23.976)
    And then merged both encodes and finally got fine rip with no jerky playback, no skipping and etc.
    It's crazy why this doesn't work when encoding whole movie at once.
