  1. Member Groskie's Avatar
    Jan 2014
    Uruguay
    Hello i'm new here, I want to buy an Avermedia DarkCrystal HD Capture Pro PCI this card is good for all uses? for example I will use it for rip VHS and LD and sometimes for record HD gameplays.
    Specs.
    Input Signal:
    S-Video
    Composite (RCA)
    Component (YPbPr, 1080i/720p)
    HDMI (1080i/720p)
    Analog Audio L/R
    Support resolution: 480i / 480p / 576i/ 576p/ 720p / 1080i (50/60 Hz)
  2. The C027 is very poor for VHS, and analog video in general. It won't lock onto nonstandard or unstable video, and it oversharpens its SD analog inputs.
    Its component captures don't quite reach the full horizontal resolution. It is good for HDMI captures, but there are cheaper alternatives that offer progressive input modes as well.
    I liked it for its time, but it's an old card at this point.
    HD capture cards that include composite & S-Video do so as an afterthought. You're better off buying a decent HD capture card and a decent SD capture device separately.
  3. Member Groskie's Avatar
    Jan 2014
    Uruguay
    Thanks for the reply, which card you recomend?
    In my country I don't have too much options to select. The EasyCAP is the most popular here lol
    Other options are
    - AverMedia AverTV HD PRO H868 USB
    - Avermedia H751 PCI Ex1
    - Kworld DVD Maker USB 2.0 (VS-USB2800D)
    If none of these is good, what card is good for analog video?
    sorry for my english, I hope you understand.
    AMD FX-6300 Six-Core at 3.8 Ghz, Asus M5A97 EVO, Radeon HD 7750.
  4. Don't know anything about those.
    I'm not even sure which TV system Uruguay uses so I probably shouldn't give specific recommendations.
