Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 12 of 12
    Jul 2005
    Scott City, Kansas
    I am wanting to use a weather template for sony vegas but just can't seem to find any. I find some for AE but not for Sony Vegas. Does anyone know where I can find one. I don't have the time right now to make one and really am not good enough either to do it. If anyone could point me to a link I would appreciate it because I am not finding anything.
  2. What exactly is a weather template? Do you mean a background showing clouds or storm, etc?
    Inside Every Older Person Is A Younger Person Wondering What The Hell Happened.
    Jul 2005
    Scott City, Kansas
    Monday
    85
    Sunny
    This kind of stuff. Where they show the temp, day and the kind of stuff that the weather man shows on the green screen wall.
    Apr 2003
    I just looked and could not find any either. If you have AE or know someone who does, you could just purchase the templates for AE and render them out as video with a transparent background and then import those into Vegas. For those graphic elements that have to be changed frequently, just don't render those out and replace them with graphic elements in Vegas.
    Brainiac
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Try Googling "Weather Graphics". I found a whole bunch.
    Jul 2005
    Scott City, Kansas
    I guess I'm not seeing what you are. I see things under weather graphics but nothing that works in Vegas. I guess After Effects is the only way to do it but weather graphics brings up more things that are for whole weather maps instead of 7 day graphics. I must be looking in the wrong place I guess.
  7. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Here's some simple ones http://www.forecast.weather.gov/
  8. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    What format are the templates in? The one I saw in a video looks like it saves as an .xml format. I think Vegas can import xml via scripts.
    Jul 2005
    Scott City, Kansas
    That link does not work.
  10. Inside Every Older Person Is A Younger Person Wondering What The Hell Happened.
    Jul 2005
    Scott City, Kansas
    Thanks. Not sure how to use the 7 day report though.
  12. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Take the graphics off on this:
