Results 1 to 16 of 16
    Jan 2014
    LEEDS,ENGLAND
    My burner has suddenly stopped recognising DVD-RW discs, I' m using VERBATIM--SONY--TDK discs, it comes up with BURN FAILURE, No problem with normal blank discs ?
  2. Member DB83's Avatar
    Jul 2007
    This may be relevant to burners as it is with stand-alone dvd-recorders. I have two recorders and, in theory, both should be able to use 2x disks. One will accept them fine but the other refuses them. I think it is down to the dye.
    Most disks are not manufactured by the name on the disk. Certainly Sony do not make theirs and it is my Sony recorder that refuses Sony disks.
    Jan 2014
    LEEDS,ENGLAND
    There are only 4 DVD manufacturers.
  4. Member DB83's Avatar
    Jul 2007
    You may also wish to expand on your problem.
    Is this happening with only the new disks you have bought or ALL disks including older ones that you have ?
    Jan 2014
    LEEDS,ENGLAND
    new discs
  6. Banned
    Freedonia
    Your burner is dying. This problem is a sign of it. You won't be able to fix this by doing anything to the burner or by using specific brands of DVD-RW.
    Jan 2014
    LEEDS,ENGLAND
    thanks
  8. You could try a firmware update, check the manufacturer's support site.
    Jan 2014
    LEEDS,ENGLAND
    thanks
    Jan 2007
    do you mean "RAM" disc's
    Jan 2014
    LEEDS,ENGLAND
    no
  12. Video Restorer lordsmurf's Avatar
    It's dying.
    The lower-reflectivity/compatibility RW/RAM media goes first.
    Then write-once 'R' media is next.
    Then ROM media goes.
    And it often happens pretty quickly, in a matter of months.
    Buy a new one. DVD burners are cheap now ($20). I still remember when mine was $900 in 2001.
  13. Banned
    Freedonia
    What lordsmurf said plus my experience has been that the ability to burn DL media actually goes first. You may be able to squeeze some more successful burns of DVD+/-R discs but I'd advise against trying to burn DL media if RW discs are already problematic.
    Jan 2014
    LEEDS,ENGLAND
    thanks
    Nov 2012
    USA
    It is possible the laser lens needs clean up.
    Jan 2014
    LEEDS,ENGLAND
    don't know
