  1. I'm using VideoBrowser. I just finished editing a movie clip to which I added some text and music.
    I then discovered an error in the text. I brought the edited clip back in to re-edit it, but the timeline showed only the Video edit line; the text and audio lines were blank. However, the film still played fine with the audio and test.
    I then tried to put in new text; I thought the new text would replace the old one, but instead I ended up with both.
    Is there any way to delete the original text without starting all over from scratch?
    Mar 2008
    You forgot to divulge some important info - what is the file type?
    Use Mediainfo in text view and post the info here.
    Here's a link to the portable version:
    http://www.videohelp.com/download/MediaInfo_GUI_0.7.67_Windows_i386_WithoutInstaller.7z
  3. It's AVCHD Video (.mts)
