  1. Hmm where to ask...my tv is a plasma with 2 usb inputs. When I watch HD 1.5 gig mkv/avi/mp4 files there's no problem but sometimes audio is out of sync after ff or rewinding..and it's always an mp4 file. Is it differences in how they are encoded? Can I run a header fix instead of a re-encoding.
    Of course on the computer there's no playback problems. My plasma model is 2010 Samsung PN58C550G1FXZA
    Post the mediainfo report from some of the mp4 files that cause sync issues. It could for example be variable framerate.
  3. If you don't have problems with MKVs as a rule, try remuxing a problem MP4 as an MKV with MKVMergeGUI (no re-encoding). If the issue is something like a variable frame rate as Baldrick suggested, remuxing probably won't help, but if the TV just doesn't play nicely with MP4 files it probably will. MKVMerge will open quite a few different file types and remux them as MKV. MKVMergeGUI makes working with MKVs pretty easy... deleting unwanted streams, replacing audio.... that sort of thing.
    I have a Samsung Plasma of around the same vintage. I dislike MP4 anyway, and I mostly remux them as MKV before playing them, so I can't really comment on how well my TV plays MP4 files.
  4. Thanks for the help! It does have variable frame rate. I used to read and apply all knowledge from this site almost 10 years ago. Lot's changed since then. Everything is all h264/mkv etc, etc now...
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 2h 59mn
    Bit rate : 819 Kbps
    Width : 720 pixels
    Height : 354 pixels
    Display aspect ratio : 2.40:1
    Original display aspect ratio : 2.40:1
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 19.969 fps
    Maximum frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.134
    Stream size : 1.03 GiB (83%)
    Writing library : x264 core 130 r2273 b3065e6
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Encoded date : UTC 2014-01-02 07:42:11
    Tagged date : UTC 2014-01-02 08:05:49
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Avoid variable frame rate video if you want to fast forward on your samsung....
  6. Looks like a Handbrake encode. I still don't understand why it adds BT.709 as the transfer characteristics for NTSC or PAL standard definition.
    Anyway.... I'd still try remuxing it as an MKV with MKVMergeGUI. You never know, the TV might cope with VFR in an MKV better than in an MP4.
