    Mar 2003
    Canada
    Hello,
    I bought David Attenborough Life on Earth in BluRay but it will not play in my Sony BDP-S3100 BluRay player, everything else I have is fine including other Blurays from BBC.
    If I rip the episodes to my media player they play fine but they are big so I shrunk them with Handbrake but they will not play.
    On my computer they play fine in VLC but in WMP I get video but no sound.
    I was wondering if anyone knew why they won't play on my player and why I can't encode them.
    Below in the output from MediaTab:
    ===================== General =====================
    Complete name : F:\toShrink\06 - Invasion Of The Land.m2ts
    Format : BDAV
    Format info : Blu-ray Video
    File size : 14.1 GB
    Duration (ms) : 55mn 1s
    OverallBitRate_Mode/String : Variable
    Total bitrate : 36.6 Mbps
    OverallBitRate_Maximum/Stri : 48.0 Mbps
    ===================== Video =====================
    MenuID/String : 1 (0x1)
    Format : AVC
    Format info : Advanced Video Codec
    Format profile : High@L4.1
    Use of CABAC : Yes
    RefFrames : 4 frames
    Codec Id : 27
    Bitrate mode : Variable
    Bitrate maximum : 39.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Aspect ratio : 16:9
    Framerate : 25.000 fps
    Colorimetry : YUV
    Colos space : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    ===================== Audio =====================
    Format : DTS
    Format info : Digital Theater Systems
    Format profile : MA / Core
    Format settings mode : 16
    Format_Settings_Endianness : Big
    Muxing mode : Stream extension
    Codec Id : 134
    Duration (ms) : 55mn 0s
    Bitrate : Unknown / 1 509 Kbps
    Channel(s) : 2 channels
    ChannelPositions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression_Mode/String : Lossless / Lossy
    ===================== Text =====================
    Format : PGS
    Codec Id : 144
  2. You don't have a DirectShow DTS decoder.
    And the handbrake output? mp4 or mkv? what video settings?
    Nov 2003
    West Texas
    Take a look at your other BBC Blu-ray discs (the ones that work in your Sony player), and see if they also show up as 25fps and MBAFF scan type.
    Mar 2003
    Canada
    Thanks for the great replies and sorry for not giving enough info for the Handbrake conversion.
    I installed a DirectShow DTS decoder and I can shrink them now.
    The fps for one that works is different it's 23.976 and so is the scan type, it's Progressive.
  6. I'm a Super Moderator johns0's Avatar
    canada
    Sony ntsc blu-ray players will not play pal blu-ray authored discs,just encode to mkv with handbrake and it will play pal mkv as long as you didn't use any weird encoding values.
