I would like to burn DVD's using an A04 burner. I have DVDit software presently. I am somewhat confused about the entire process, but the DVD's I will be burning will be about 1 hour and 15 minutes each. Will the encoder used bt DVDit PE be sufficient to keep my quality high or will I need some other encoder? I plan to take avi files from my Canopus DV Rex RT system into DVDit PE, assign the chapters and menu's and encode and burn using this same software. Will I need anything else? Are other encoders and/or software better as far as quality of the finished DVD are concerned? Phil in Montana
Results 1 to 1 of 1
Thread: Are all encoders equal?
how many MB equal GB/ how many episodes can i fit on disc?
By janeydoll in forum Video ConversionReplies: 6Last Post: 21st Oct 2010, 09:20 -
Are all BR players created equal?
By pianoman1976 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 22nd Apr 2010, 11:18 -
Are all networkable players equal?
By glen_s in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Nov 2009, 10:43 -
Is one of these capture methods better for quality than the other or equal?
By twolf13 in forum CapturingReplies: 3Last Post: 20th May 2008, 10:12 -
Different size but equal quality?
By mai_hnf in forum Video ConversionReplies: 4Last Post: 5th Oct 2007, 09:59
