  1. I have a few recordings that feature a bit of shaky camera, and whenever I try to patch together in an editor (VSDC Free Video Editor at the moment), the result becomes incredibly blurry whenever the camera jerk a little bit. The originals are shaky, but not unwatchable by any means. I've tried everything I can think of, frame rate (25 fps), resolution (720x576), bit rate (8000 kbps maximum), display aspect ratio (16:9), everything is identical, but however I try to convert, the result is a smeared piece of shit. What could I possibly be misunderstanding about video conversion?
    > Video ID : 224 (0xE0)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Duration : 59s 440ms
    Bit rate mode : Variable
    Bit rate : 7 836 Kbps
    Maximum bit rate : 8 400 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.756
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 55.5 MiB (93%)
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.470 System B, BT.470 System G
    Matrix coefficients : BT.601
    > Video
    Format : MPEG Video
    Format profile : Main@High 1440
    Format settings, Matrix : Default
    Duration : 2mn 3s
    Bit rate : 6 323 Kbps
    Maximum bit rate : 8 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.429
    Stream size : 92.8 MiB (93%)
  2. Don't deinterlace it if you're going back to MPEG2 for DVD
    Notice how it was interlaced before, but progressive after ? Your program is probably applying a single rate blend deinterlace . 25 frames/s interlaced is 50 fields/s, so the motion is smoother than 25 progresive frame/s
  3. I don't see deinterlacin anywhere, would that be on conversion or import? I don't really know what deinterlacing is
  4. Originally Posted by IndianaP View Post
    I've never used that program, but for most editing programs, there will be a project or timeline settings, AND export settings. Make sure both are set to 720x576 25 frames/s interlaced
    It's a big topic, but at the most basic level, deinterlacing is converting interlaced to progressive . Use search if you want more info
  5. Originally Posted by poisondeathray View Post
    I cannot find "interlace," "deinterlace," "progressive," or "scan type" anywhere other than the file description. I guess I'll have to move on to a different program. Thanks for the response though
