Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
    Mar 2004
    I'm having a problem with the Freemake Video Converter.
    For some reason, whenever I try to import a ripped DVD into Freemake, it only recognizes the movie as 25 frames per second.
    This happens whether I choose to import either an .IFO or a .VOB file. However I have used the GSpot Codec Appliance tool to confirm that the .VOB files are 23.976 fps.
    I contacted Freemake support, they had me upload the movie files I was having trouble with, then after a long while, they simply told me to download the latest version. That didn't help.
    Thinking it might be a problem with my system, I installed Freemake on a computer that just had Windows XP-SP3 freshly installed - but I'm having the exact same problem. Freemake wants to import every DVD as having 25 fps.
    Has anyone run into this problem?
    I have a bunch of DVDs that I'd like to convert to digital files for use on my Blu-Ray player.
    And you are clicking on the "+DVD"-button to import it? And maybe select the ripped VIDEO_TS folder.
    But I have never used it for dvd to conversions. I used to like autogk, fairuse wizard le, or xvid4psp 5 for dvd to avi conversions and vidcoder for dvd to mp4/mkv conversion.
  3. Originally Posted by Baldrick View Post
    I used to like...
    What do you like now?
    I don't like to convert now.
  5. Originally Posted by Tchail View Post
    Are you claiming your Blu-Ray player won't play DVDs?
    And if you can't make Freemake do what you want (don't know as I don't use it myself), is there any reason you can't use a different freeware program, like the ones Baldrick mentioned?
  6. Originally Posted by Baldrick View Post
    That's my mindset.
    It is too easy to copy to hard drive and use a media player or some BD players to play the files.
    For the OP, choose another program to do what you want.
    If you were to tell what you are trying to accomplish, we could give advice.
