  1. I would like to simply swap out a title on a DVD without having to relocate the files and re-encode the whole DVD.
    In this example, there are just 2 titles
    VTS_01
    and
    VTS_02
    and a menu
    If I author a different 2 title DVD, may I swap this set of VTS_02 files for the original on the other
    both have only three files for title 2 -
    VTS_02_0.BUP
    VTS_02_0.IFO
    VTS_02_0.VOB
    They are both basically authored the same way.
    May I just swap them out? Or would this possibly create some compatibility or playback issue? I tested and seems ok, but I would like your opinions. - thanks
    Are you just replacing the files?
    It might not work as expected on all players. Try instead use vobblanker and use the replace function. Click on it for some guides.
  3. i forgot vobblanker had a replace function, thank you )
