  1. I have an AVI video that has this info:
    Codec: H264 - MPEG-4 AVC (part 10) (H264)
    Resolution 352x240
    Frame Rate: 29.970029
    Decoded Format: Plana 4:2:0 YuV
    The quality isn't that good. It was from security camera footage for a burglary. I'm trying to make it clearer to see faces, and just overall better quality!
    I'm very dumb when it comes to this stuff, but can anyone tell me if it is even possible to create a higher quality video from this in any way? Also, is it possible to create a much "bigger" pixel video with good quality? I'm not concerned with filesize or anything else other than better quality!
    HELP!!
  2. Banned
    Nov 2005
    Resolution 352x240
    HELP!!
    you can't make a silk purse out of a sow's ear. you can clean it up a bit with some filtering but don't expect too much.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You can't "increase" quality. As noted, filtering may clean it up a bit, but based on the source, it won't be the type of detail that you are wanting. You can't add data/information/detail that isn't in the source material.
    Google is your Friend
    Mar 2008
    "security camera" sounds like an oxymoron. How often have we seen security footage that
    is so poor, it's worthless? So much for security.
  5. Banned
    Nov 2005
    security cameras were never meant to be used as a stand alone device, they were meant to be actively monitored by security personal who could then respond if they saw something going down.
    but on their own they're practically worthless, you're better of spending the money on some strong door and window bars and some strong locks.
  6. thanks for the replies(I think). Can anyone help me out a little more by suggesting exactly what I can try? I've messed around with VLC player's filters but not much there. I wonder, that if the video is interlaced, would de-interlacing it with some filter help "clear" the picture?
    any other suggestions are greatly appreciated. thank you!
    Mar 2008
    Can you post some of the video so we can get some better idea's ?
  8. Member Ethlred's Avatar
    Feb 2008
    Resolution 352x240
    I have never seen interlacing at that resolution. It is usually the result of throwing out the half the lines thus removing the interlacing.
