Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 12 of 12
    Sep 2013
    Texas , USA
    Hello & Thanks ,Sometimes the music videos on youtube are off pitch, for example:
    https://www.youtube.com/watch?v=CQpJHWgKCMQ
    Audacity can change the pitch in semitones (half-steps) ,
    but the pitch is less off than a half-step .
    ie., if the note is of by 50% of a half-step ,
    whether I go up or down a half-step , its still off by 50% .
    Is there a software (freeware?) that can do this ?
    Thanks..Vernon
  2. Audacity can change the pitch by any amount, not just semitones. Enter a decimal value in the "Semitones (half-steps)" field -- like 0.5 to get half a half-step. Or you can enter a decimal value in the "Percent Change" field.
    Sep 2013
    Texas , USA
    My mistake , Thanks , that's great .
    What program can I use to merge the new file back into the .mp4 file ?
    Thanks..vm
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Probably the quickest way not involving any re-encoding is to put it in a mkv container using mkvmergegui. You can then add the extra soundtrack and untick the original within the mp4 file. mkvmergegui will remux it for you.
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
    Sep 2013
    Texas , USA
    Hmm...Ok,
    I used video2video (v2v) to turn myfile.wmv into myfileV.mkv
    Then with mkvmergegui, i extracted myfileV.mkv into myfile.h264 . (just the video)
    I then used Audacity to create changedPitch file (from myfile.wmv) into myfileA.wma . (just the audio)
    I tried turning them both into .mkv files ,
    but mkvmergegui will only accept 1 mkv file at a time.
    Pls, how can I now merge myfile.h264 and myfileA.wma ?
    Thanks..vm
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    With mkvmergegui you just use the Add button to add in each file.
    Sep 2013
    Texas , USA
    Sorry , but I can't find a download for mkvmergegui . Its not in mkvmerge-gui.html
    or
    http://www.bunkus.org/videotools/mkvtoolnix/downloads.html
  8. Originally Posted by vmars316 View Post
    It's mmg.exe, part of MkvTookNix.
    Sep 2013
    Texas , USA
    Ah, piece o' cake .Thanks
    Sep 2013
    Texas , USA
    Originally Posted by smartel View Post
    Yes it does , Thanks .But it sometimes crashes: win7 x64 .
    Wavosaur also does a good job , but its very slow .
    vm
  11. Member spiritgumm's Avatar
    Jan 2004
    I think you mean the video is not re-encoded. The new audio track is a re-encode. Is there a way to change the audio pitch in the MKV without re-encoding the audio?
