  1. Member Frank-0-Video's Avatar
    Jan 2009
    Alabama - United States
    Greetings ....
    Recently bought a Dynex 4-port USB Hub (see attached image) that has an input for power from an AC adaptor. However, no AC adaptor came with the hub. If multiple external hard drives are attached, some do not work because of a lack of adequate power.
    On the back of the hub itself, a notation says that input power of 5 volts at 2.0 Amps is recommended.
    If there is an AC adaptor with multi-voltage settings, plus interchangable plugs that you know of which will work with this hub, please let me know.
    Thanx-A-Lot, Frank-0-Video
    THE Ultimate TV Tuner Device - Picks up every broadcast-cable-satellite transmission since 1928!
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Radio Shack usually carries one with multiple voltages and available multiple connectors. Otherwise mail order, but then the connector may be wrong.
    They are not really standardized.
    RS has less of those type of power supplies than in the past, but you could try one of their stores. And take the hub with you for the proper connector.
