  1. Hello
    is it possible to change the resolution of a wmv file (or my logic tells me this would apply to any file) without re-encoding the video?
    If yes, what software should I use to do this?
    No.
  3. OK thank you, I guess it was logical. That applies to any file, right?
    I had a slight hope that with the advancement of technology this would be somehow possible
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If the resolution is changed, the file has to encoded to make the adjustment (remove data for a decrease or create data for an increase). The "advancement of technology" and increasing PC power simply means the process takes less time.
    Google is your Friend
