Results 1 to 13 of 13
  1. Hi, I have been capturing live tv on my pc and I have trouble getting exactly what I want. So I came here for advice/help
    What I want to do is end up with a file that will be as close to the scene releases that are made (from well known release groups).
    I am using the following capture card: AverTV HD DVR (C027) and using AverMediaCenter to record the stream (connected via HDMI and using a hacked versionthat removed the HDCP protection).
    My cable box is configured to output 720p video and I'm capturing from and HD channel
    My first concern is what are the best format (and settings) to record the stream in AverMediaCenter?
    Should I capture in MPEG-2 or H.264?
    What Settings should I use for the capture (for the better format)? (resolution, bitrate, audio setting etc...)
    After that I usually need to cut the video file (ie to remove commercials and get the good starting and ending position) I currently use Boilsoft Video cutter.
    Should I cut the file before converting it or should I do the conversion first and then cut the file?
    right now I was using Boilsoft Video cutter to re-encode the video, but I also used handbrake (if I remember correctly) in the past to convert it to the desired format.
    The final format I would want to achieve is to have a MP4 file that is close the the scene standards (not a HD release, I want something like what the group LOL is releasing for The Simpsons).
    What should I use to convert and what settings should I use?
    I'm asking for a lot of information, but any help would be appreciated. I'm lost in all those settings and options.
    If you need more information on my setup/needs I will gladly provide them.
    thanks
    The_Dogg
    Capture in 720p with highest possible bitrate. Try h264.
    Cut with boilsoft if you can save the video lossless.
    Shrink with megui. Use the one click converter and try different presets that matches scene releases.
    But I guess many scene releases are made from sources that are digital recorded directly instead of captured.
  3. thanks, I will try that, this helps me a lot
    The_Dogg
  4. Originally Posted by Baldrick View Post
    I'm having issues with the video created with MeGUI, I noticed that the resulting file has 21fps and this is what I suspect the problem is (Audio seems out of sync) I can't find any settings to specify the fps. any idea?
    The_Dogg
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Post the details from your captured video.
  6. Originally Posted by Baldrick View Post
    GeneralComplete name :   C:\Users\The_Dogg\Videos\20140109123830.mp4
    Format :   MPEG-4
    Format profile :   Base Media / Version 2
    Codec ID :   mp42
    File size :   976 MiB
    Duration :   13mn 24s
    Overall bit rate mode :   Variable
    Overall bit rate :   10.2 Mbps
    Encoded date :   UTC 2014-01-09 17:38:33
    Tagged date :   UTC 2014-01-09 17:38:33
    Video
    Format :   AVC
    Format/Info :   Advanced Video Codec
    Format profile :   Main@L3.1
    Format settings, CABAC :   Yes
    Format settings, ReFrames :   2 frames
    Format settings, GOP :   M=1, N=30
    Codec ID :   avc1
    Codec ID/Info :   Advanced Video Coding
    Duration :   13mn 24s
    Source duration :   13mn 24s
    Bit rate mode :   Variable
    Bit rate :   9 854 Kbps
    Maximum bit rate :   12.0 Mbps
    Width :   1 280 pixels
    Height :   720 pixels
    Display aspect ratio :   16:9
    Frame rate mode :   Variable
    Frame rate :   52.795 fps
    Original frame rate :   30.000 fps
    Minimum frame rate :   7.059 fps
    Maximum frame rate :   60.000 fps
    Color space :   YUV
    Chroma subsampling :   4:2:0
    Bit depth :   8 bits
    Scan type :   Progressive
    Bits/(Pixel*Frame) :   0.203
    Stream size :   945 MiB (97%)
    Source stream size :   945 MiB (97%)
    Language :   English
    mdhd_Duration :   804563
    Audio
    Format :   AAC
    Format/Info :   Advanced Audio Codec
    Format profile :   LC
    Codec ID :   40
    Duration :   13mn 24s
    Bit rate mode :   Constant
    Bit rate :   320 Kbps
    Nominal bit rate :   128 Kbps
    Channel(s) :   2 channels
    Channel positions :   Front: L R
    Sampling rate :   48.0 KHz
    Compression mode :   Lossy
    Stream size :   30.7 MiB (3%)
    Source stream size :   30.7 MiB (3%)
    Language :   English
    mdhd_Duration :   804820
    that is the video from the capture, I can post the details of the converted (MeGUI) file if you want them also
    The_Dogg
  7. Broadcaster bigass's Avatar
    Dec 2006
    Halifax, NS Canada
    Well, don't record at variable frame rate. Record at the frame rate that matches the source.
    Your recording says:
    Frame rate mode : Variable Frame rate : 52.795 fps Original frame rate : 30.000 fps Minimum frame rate : 7.059 fps Maximum frame rate : 60.000 fps
  8. Originally Posted by bigass View Post
    I'm using AverMediaCenter to record and I dont see any setting for the frame rate.
    here are the settings I have and the values i used:
    The_Dogg
    Mar 2008
    Instead of AverMediaCenter, try an alternative software. Perhaps AmarecTV ?
  10. Banned
    New York, US
    Variable frame rates are not valid for standard BluRay/AVCHD or DVD.
    The specs: http://www.videohelp.com/hd#tech
  11. Originally Posted by sanlyn View Post
    You can't use MPEG2 for standard HD. And you won't see "MP4" listed as valid for any HD disc format.
    Be careful about using the term "convert". I think what you really mean is "re-encode," which entails quality loss.
    Yes you are right I meant re-encode.
    My goal is not to have my files on a disc, I'm just trying to have files similar to what the release groups are doing.
    I did a capture test with avermediacenter, I captured in MPEG-2 and it gave me a constant frame rate of 60 fps.
    but now when I re-encode with MeGUI the resulting file is also 60 fps, is there any way to specify it in MeGUI?
    I will also try handbrake to re-encode and see if I can achieve my desired result
    The_Dogg
  12. Originally Posted by davexnet View Post
    I havent tried any other program to capture yet. I read somewhere that the card I'm using only works with AverMediaCenter (but I'm not sure that information is true). I do like the fact that I found a hacked version (in this forum) that removes the HDCP protection so I can now ditch my component cables and use hdmi.
    I also want to make use of the scheduling in AverMediaCenter, but I cannot get it to work at all, the new entry that I create never appears in the list.
    So if I were to use another program I would want that it has a way to schedule recording. If you know any please let me know.
    The_Dogg
  13. Banned
    New York, US
    I don't we know what the release groups are doing.
    That's the proper frame rate for 1280x720 HD (properly, it's 59.94p). Other allowable rates are 24p and 23.976p. 16:9 square-pixel DAR is all you can use, as well. If you're using MPEG2, BluRay disc is the target delivery format.
    Again, look at the standard specs: http://www.videohelp.com/hd#tech
