  1. Greetings to all
    I have two subtitles.
    One that is correct, in english,
    and the other (greek) that is out of sync and the sentences don't match those of the english subtitles.
    I mean that, they are not 1-1: some sentences match while others are not in the greek subtitle at all
    or take two lines in the english and in greek they take one line.
    eg.
    english subtitle
    1
    phrase 1
    2
    phrase 2
    3
    greek subtitle
    1
    phrase 1
    2
    phrase 2, 1st part
    3
    phrase 2, 2st part
    Is there a tool to load the two subtitles side by side
    (something like the Subtitle Edit feature: File>open original file(translator mode))
    and then split/merge/insert lines in the greek subtitle only
    so that the greek sentences then match to the english ones?
    If I can manage this,
    then I can do a File>import timecodes
    from the english subtitle
    to the "aligned" greek
    and it will be in sync.
    Thank you
  2. I found it:
    it's in Subtitle edit (translation mode):
    right click on a subtitle>Column>Insert/delete text and shift cells up/down.
