Results 1 to 9 of 9
  1. Hello folks,
    Iam trying to convert image from GIF to JPG using FFMPEG ,the following commands which i tried
    D:\FFMpeg\FFMpeg_Latest>ffmpeg -i "C:\Documents and Settings\Admin\Desktop\Natur
    e.gif" -y -s 174x96 -pix_fmt rgb24 "C:\Documents and Settings\Admin\Desktop\Natu
    re.jpg"
    But i got C:\Documents and Settings\Admin\Desktop\Nature.gif: could not find codec paramet
    ers
    Can anybody send me the command line for converting GIF to JPG......
    Thanks in Advance!
  2. This works for me:
    Using rgb instead of yuvj420p gave an warning message but it still created the jpg file.
    I'm moving you to our video encoding section as ffmpegx is not same as ffmpeg.
    canada
    Wouldn't it be more simple to open the gif with paint and save as jpg?
  5. Originally Posted by johns0 View Post
    Maybe he has lots of them. In which case automation is in order. The command line I gave could be used with minor modifications in a batch file to convert all gif files in a folder to jpg. Even all gif files in a folder tree.
  6. I'm a Super Moderator johns0's Avatar
    canada
    There's other programs that can do batch gif to jpg as well such as irfanview.
  7. Here's a batch file that will convert all gif files in the folder the bat file is in, and all sub folders down from there, to jpg files with the same base name. The original gif files are left untouched. Animated gifs will result in a jpg file with a single frame.
    dir/b/s *.gif >giflist.txt
    for /F "delims=;" %%F in (giflist.txt) do "c:\program files\ffmpeg\bin\ffmpeg.exe"  -i "%%F" -y -s 174x96 -pix_fmt yuvj420p "%%~dF%%~pF%%~nF.jpg"
    del giflist.txt
    Change the path to ffmpeg.exe if necessary.
  8. AviDemux can save as a sequence of images.
  9. http://luci.criosweb.ro/riot/
    Much easier, batch support, and can be integrated into GIMP.
