Results 1 to 11 of 11
    Jan 2014
    Hi,
    Generally speaking, do all devices which output video (game console, dvd player, blu ray player etc.) work in the same way?
    Is it transport (HDMI, component etc.) specific?
    For example does my PS4 HDMI say to my hdtv , here is 1080p 60 fps video data, and the hdtv does whatever it has to in order to display that?
    Or is it more like the PS4 HDMI says to my HDTV, what can you do? And based upon the response the PS4 does what it needs to do to get the HDTV what it needs?
    Feb 2004
    Australia
    1: Same no ... similar yes
    2: Depends on device output capabilities, some are multi optional
    3: Is specific, term is handshake ... exactly, the majority of tv's will display the source even if the screen isn't full 1080 capable.
    4: No
  3. It depends on how the source is set up. If the source is set to "automatic" mode it will query the sink (TV) for it's capabilities and select an output format supported by the TV. If the source is forced to a specific output format the sink will not display a picture if it doesn't support that format.
    Jan 2014
    What happens when you have two sinks connected through a powered HDMI splitter?
    Does the splitter act as the sink to the source, and as the source to the two connected sinks?
  5. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I use a powered HDMI splitter and it outputs to both my HDMI compliant LED monitor and a HDMI video projector at the same time. I don't think the splitter is considered a 'sink' as it's a pretty basic device.. I think the monitor and the projector are both compliant so both have a equal signal. No idea how the output devices (A PC, a BD player or a WDTV Live) see them.
    Jan 2014
    Based on Jagabo's answer, I was curious what would happen if you had a 720p tv and a 1080p tv hooked up to the splitter.
    Does the source see it as two sinks and it queries both and defaults to the lowest common denominator?
  7. Originally Posted by comp1mp View Post
    From the behavior I've seen I believe the splitter passes the query through to one of the devices and performs the handshake. Then the rest of the devices get the same format. If the negotiation happens with the device with higher capabilities first the second device fails to deliver a picture.
    Jan 2014
    Interesting. Is HDMI backwards compatible?
    Taking your belief, if I had two 1080p sinks, one HDMI 1.2 and one HDMI 1.3 and the 1.3 device was queried by the splitter, would the 1.2 device work?
  9. Originally Posted by comp1mp View Post
    Yes. I suppose it's possible that a particular device might not support all the older input formats. That would be stupid on the part of the manufacturer though.
    Jan 2014
    I actually meant the other way. If a 1.2 hdmi sink received a 1.3 stream, would it be able to use it.
  11. Originally Posted by comp1mp View Post
    Not if the 1.3 source uses features that weren't a part of 1.2, DTS-HD for example.
