Hello to all! I have a Vizio E370VL flatscreen tv hooked to a metrocast hd box. When I go to turn my tv on and hit hdmi 1 the tv comes on and says retrieving data then it says not support. It then takes five minutes for the picture to come on but it flashes for a few minutes and then settles down and plays normally. Is there a simple solution to this?
I would first try a different HDMI cable. HDMI does a 'handshaking' to ensure that the units on both ends of the cable are HDCP compliant. That is sometimes slow. This is for digital copy protection. Thank Hollywood for this.
http://electronics.howstuffworks.com/hdmi1.htm
As it does work (eventually), I'd say the cable is OK. Most likely a fault (or glitch) with the cable box or TV.
Should be easy enough to get the box swapped out.Google is your Friend
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
PC to TV via HDMI problem
By cambridge7579 in forum Media Center PC / MediaCentersReplies: 0Last Post: 11th Jan 2010, 10:54 -
HDMI Problem !!!
By enesture in forum Newbie / General discussionsReplies: 7Last Post: 22nd Nov 2009, 23:49 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40
