  1. Dear FriendsI am new to video capturing I have just started my project
    I wanted to do video capturing project which will capture/edit videos in a good quality
    like mepg1, mpeg2 , AVI etc .
    I need your advice for selecting the codec which is the best codec i should used
    which will not give big size files but good quallity vides
    Mar 2011
    Nova Scotia, Canada
    While I'm not one of the capturing experts here by any means, what I'd do is capture to lossless ... which will be very large ... and then convert it to something of a more manageable size.
  3. The best capture is an exact duplicate of your original source -- simply copy it if you can. Hoser Rob's advice is certainly the highest quality way to handle material that must be converted.
    May 2003
    Peterborough, England
    mpeg1 and 2 are final formats, not editing formats. As said, you want something that doesn't compress at all but what you use will depend to a certain extent on what you are capturing from and how.
  5. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    I'm assuming you're capturing from VHS?
    Whatever you end up with, MPEG-1/2, DivX, Xvid, H.264, whatever highly compressed format, you're better off starting with a lossless capture.
    Many formats were not designed for capture very well, only for compressed playback. Lossless formats, such as HuffYUV, UT, Lagarith, are much better suited for capture (and all comfortable in an AVI).
    Yes, the file size will be considerably bigger with lossless, but it doesn't matter. After you finish the capture, you can edit, filter, process etc, and THEN convert it to another smaller sized format in the end.
    The quality will always be better using capture->lossless->high compressed format, than directly from capture->high compressed format.
    You're always better off starting with lossless when dealing with such analog source formats.
    I hate VHS. I always did.
