Removing profile, level => becomes "0", but high @ L3.2
Removing level, keeping --profile main => becomes "1"
Removing profile, keeping L4.0 => becomes "1", but high@L4.0
After some googling - I think it has something do to specifically with an x264 patch that sets it to behave that way
Results 31 to 39 of 39
Might be, also I too suspect that it is not really needed for stream compatibility.
No you don't
If your x264 is compiled with lavf, you can load the videos directly . Just use --demuxer lavf . The binaries here have lavf
http://komisar.gin.by/
I only used avisynth to stack the test videos, side by side -
Just Ran X264 with a combination of you options
When I tried to run MP4BoxPS D:\3D Cam\test\x264> .\x264.2377.x86_64.exe --profile main --level 4.0 --preset faster --vbv-maxrate 20000 --vbv-bufsize 25000 --bitrate 3888 --weightp 0 --deblock 0 --bframes 0 --keyint 15 --ref 1 --demuxer lavf -o TS3hist.264 .\TS3.mp4
lavf [info]: 368x208p 1:1 @ 24000/1001 fps (vfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
x264 [info]: profile Main, level 4.0
x264 [info]: frame I:529 Avg QP: 0.65 size: 41667
x264 [info]: frame P:5476 Avg QP: 0.57 size: 8861
x264 [info]: mb I I16..4: 6.2% 0.0% 93.8%
x264 [info]: mb P I16..4: 1.5% 0.0% 11.3% P16..4: 48.6% 7.6% 5.8% 0.0% 0.0% skip:25.2%
x264 [info]: final ratefactor: -9.90
x264 [info]: coded y,uvDC,uvAC intra: 86.7% 81.2% 64.3% inter: 34.2% 30.1% 17.2%
x264 [info]: i16 v,h,dc,p: 28% 13% 13% 47%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 41% 19% 17% 4% 3% 5% 3% 5% 4%
x264 [info]: i8c dc,h,v,p: 45% 14% 30% 10%
x264 [info]: kb/s:2257.26
encoded 6005 frames, 312.52 fps, 2257.26 kb/s
It is waiting for another missing option I wonder what it is ?.\MP4Box.exe -add "TS3hist.264":fps=29.970" -add "audio.m4a#1" -brand "MSNV" -ab "mp42"
-new "TS3hist.mp4"
Do you have "audio.m4a" somewhere ? Did you already encode the audio stream? x264 is a video encoder , not audio encoder (although there are private builds that can do audio)
I would add --force-cfr to the x264 commandline, because most devices don't like VFR . (avisynth frameserves CFR only, hence it's not necessary to add that) -
-> remove the "-symbol at the end,...Code:
Thank you for you input
Last trail for the day
@SelurPS D:\3D Cam\test\x264> .\x264.2377.x86_64.exe --profile main --level 4.0 --preset faster --vbv-maxrate 20000 --vbv-bufsize 25000 --bitrate 3888 --weightp 0 --deblock 0 --bframes 0 --keyint 15 --ref 1 --force-cfr --demuxer lavf -o TS3hist.264 .\TS3.mp4
lavf [info]: 368x208p 1:1 @ 24000/1001 fps (cfr)
x264 [info]: frame I:529 Avg QP: 0.58 size: 41673
x264 [info]: frame P:5476 Avg QP: 0.53 size: 8865
x264 [info]: mb I I16..4: 6.1% 0.0% 93.9%
x264 [info]: final ratefactor: -9.94
x264 [info]: coded y,uvDC,uvAC intra: 86.7% 81.2% 64.4% inter: 34.2% 30.1% 17.2%
x264 [info]: i16 v,h,dc,p: 27% 12% 13% 48%
x264 [info]: kb/s:2254.68
encoded 6005 frames, 381.75 fps, 2254.68 kb/s
MP4box command was my mistake I used power shell auto complete and it generated that extra double quotes
@poisondeathrayPS > MP4Box.exe -add "TS3hist.264:fps=29.970" -add "audio.m4a#1" -brand "MSNV" -ab "mp42" -new "TS3hist.mp4"
AVC-H264 import - frame size 368 x 208 at 29.970 FPS
AVC Import results: 6005 samples - Slices: 529 I 5476 P 0 B - 1 SEI - 529 IDR
Unknown input file type
Error importing audio.m4a#1: Requested URL is not valid or cannot be found
PS > MP4Box.exe -add "TS3hist.264:fps=29.970" -brand "MSNV" -ab "mp42" -new "TS3hist.mp4"
Saving TS3hist.mp4: 0.500 secs Interleaving
You were right about the audio it didn't work until I removed the audio part (I just copied your command).
unfortunately , It faced the same destiny of your muxed files .
I had came closer with one the conversion software I tried and I got the device to browse the output file without hanging althogh it failed at playing it.
I will have another trails later with knowledge accumulated from today's errors.
Thank you for your help today
Just got it done
The camera came with "Arcsoft TotalMedia HDCam for 3D"
So I used Arcsoft media converter , selected the default MP4 conversion profile , And it worked !!!
Thank you all for you help.
How can I convert MKV profile high@5.1 to MKV profile 4.1 ?
By utahmar in forum Video ConversionReplies: 53Last Post: 4th Nov 2012, 08:03 -
Convert MKV profile 5.1 to MKV profile 4.1 ?
By Khalua in forum Video ConversionReplies: 3Last Post: 7th May 2011, 12:52 -
Conversion of x264 High Profile 5.1 MKV 1080p to accomodate GPU
By cmwill3407 in forum Video ConversionReplies: 2Last Post: 27th Oct 2009, 23:18 -
How can I convert MKV profile 5.1 to MKV profile 4.1 ?
By Sanshero in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 03:40 -
By Sanshero in forum Video Streaming DownloadingReplies: 1Last Post: 26th Mar 2009, 12:32
