Results 1 to 16 of 16
  1. Can someone recommend to me a good Region Free Blu-Ray Player in Australia? Needs to be able to play mp4 & mkv as well. If it's a Recorder that's ok too?
    And don't mention Laser!!!
  2. Member hech54's Avatar
    Blu Ray discs have zones.
    DVD discs have regions.
  3. I'm talking about a Blu-Ray player that will play DVDs from any region.
    Being in Oz, you shouldn't have too much trouble finding a BD player that can do Region Free for DVD.
    Just check local reviews of locally available BluRay players. The rest of the World doesn't seem to be quite so lucky in that regard.
  5. Originally Posted by hech54 View Post
    The BDA calls them regions just the same as DVD: http://www.blu-raydisc.com/en/technical/faqs/blu-raydiscforvideo.aspx
  6. Member netmask56's Avatar
    Heaps available but check out JBHiFi for the Pioneer BD160 region free out of the box for DVD's and does 3D. Kogans have/had units that can switch between Bluray zones as well as DVD region free out of the box. I have a BD150 Pioneer and performs flawlessly altho' I must admit I play most movies off my network. I also have a Soniq, doesn't do 3D but you can switch Bluray zones effortlessly.
    The other option is if you are in Sydney explore Chinatown in the Haymarket for all sorts of electronic goodies.... Don't bother with the major chain's like DJ's or Myer's etc as they tend to only sell locked down models
    Expect to pay around a$130 for the Pioneer but sometimes they will be on special. If you really want to import a unit from wherever currently there is no duty or GST on imports under a$1,000 but that is likely to change in the Federal May budget. The Abbott government is money hungry so the budget is going to have a few nasty surprises.
    TheVoiceIsAnotherPerson ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030
  7. Is the Pioneer this one http://www.pioneer.com.au/au/products/BDP-160-K/print.html? If it is this one it looks wonderful, as it also plays SACD! I'm in Perth so going to Chinatown is out of the question.
  8. Member netmask56's Avatar
    Yes that's it - JbHiFi will have them and just make sure you specify region free out of the box. A technophobe friend just bought one and had no problems setting it up. I think this model has wifi built in but not sure.
    http://www.jbhifionline.com.au/home%20theatre/blu-ray%20player/pioneer-bdp-160-network...-player/691255
    Gone up to a$148 plus a$10 shipping It looks like your local WA stores don't have it so you would have to order on line from Sydney. It's worth trying a local store as you can try beating them down a tad.
  9. Member hech54's Avatar
    AH yes. I keep forgetting I no longer live in a native English speaking country.
  10. Member johns0's Avatar
    Just buy a blu-ray player that plays mkv and mp4,most if not all will play these files in 25fps and 23.976 or any frame rate in respect.
  11. But I have a lot of UK DVD's that won't play on Region 4 machines! Haven't you read the first post, johns0?
  12. Member johns0's Avatar
    I read your first post,you want to play mkv and mp4 so just convert your dvds to that format and they will play with no issues.
  13. I asked about a Region Free player that will also play these format.
  14. I went to one JBHiFi in Joondalup & the chap there confirmed the Pioneer is region free for DVDs. They didnd't have any in stock but he told me Whitfords branch (10 mins drive) had 24. I went there & was approached by a salesman whom I had just heard tell someone else that Kogan was a crook who had run dodgy businesses before? He told me that the Pioneer was not region free & that if I bought it he would not offer a refund under that case. His manner towards me was very rude I thought, & he went on to tell me that there was no such thing as a Blu-Ray player that will play any DVDs. When I pointed out that sites on the web told me this machine is region free, & that the web tells us there are plenty out there, he told me not to believe everything I read on the net!
    Anyway, I bought it & it IS region free! The moral of the story is don't believe anything a salesperson tells you!
  15. That's only for watching videos via a PC.
  16. Member netmask56's Avatar
    I'm surprised JBHiFi didn't offer to ship one from Sydney or Melbourne but they are all individual franchises. As you would probably know the law in Oz is split, the ACCC says region coding is illegal due to anti competitive nature of the practice whilst Commonwealth law allows its. Anyway you got one. Kogan's has had a few ups and downs, he imports stuff directly in container load from China hence the low prices. Some lemons but quite a few gems.
