I have Matrox DVI Convert Scan taking DVI input from PC, Composite output to TV and SDI output to SDI monitor,Problem:when i give the SDI output SDI monitor then composite output to tv video is flickering,if i remove SDI out put from the matrox DVI converter then composite tv video is fine,
please help me to solve this issue.
Results 1 to 1 of 1
SDI, Component(Y), Composite in PAL signal
By luckyo in forum Capturing and VCRReplies: 0Last Post: 18th Jun 2012, 07:22 -
Same cable for BNC, SDI and Composite?
By kayut in forum Off topicReplies: 2Last Post: 31st Oct 2011, 09:37 -
a good BOB? for DVCPRO via SDI output TO CAPTURE into Precision 690 PC?
By cowtowne in forum Capturing and VCRReplies: 0Last Post: 14th Feb 2011, 11:01 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 21:57 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46
