Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 11 of 11
    Dec 2013
    Austin, TX
    Hello,
    I have a lot of Anime in the old .ogm format (I think because it was the first dual audio stream container? correct me if I'm wrong). I am trying to batch convert this to .mp4 except I have no experience writing command line ffmpeg.
    • Copy the video
    • Convert both audio streams from .ogg to .aac
    • Copy the subtitles
    Thank you in advance for any help.
    What I've tried already:
    for %%a in ("*.ogm") do ffmpeg -i "%%a" -vcodec copy -acodec copy "newfiles\%%~na.mp4"
    pause
    This just copies video and only 1 audio stream and doesn't copy subtitles.
    You must use the map option, see https://trac.ffmpeg.org/wiki/How%20to%20use%20-map%20option for some examples.
    Dec 2013
    Austin, TX
    Ok, so that's getting me on the right track... but now I'm left with something like this and getting errors regarding invalid filename syntax:
    for %%a in ("*.ogm") do ffmpeg -i "%%a" \
    -map 0:0 -map 0:1 -map 0:2 -map 0:3 \
    -c:v copy \
    -c:a:0 libfaac -b:a:0 96k \
    -c:a:1 libfaac -b:a:1 96k \
    -c:s copy \
    pause
    Post the error output
    and don't use any \ or new line.
    for %%a in ("*.ogm") do ffmpeg -i "%%a" -map 0:0 -map 0:1 -map 0:2 -map 0:3 -c:v copy -c:a:0 libfaac -b:a:0 96k -c:a:1 libfaac -b:a:1 96k -c:s copy "newfiles\%%~na.mp4"
    pause
    Dec 2013
    Austin, TX
    It's not exactly easy or pretty
    F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>ffmpeg -i "60 - The Man Who is Chosen for Victory.ogm" \                                             ffmpeg version N-59407-gfead241 Copyright (c) 2000-2013 the FFmpeg developers     built on Dec 28 2013 22:01:59 with gcc 4.8.2 (GCC)                              configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib              libavutil      52. 59.100 / 52. 59.100                                          libavcodec     55. 47.100 / 55. 47.100                                          libavformat    55. 22.100 / 55. 22.100                                          libavdevice    55.  5.102 / 55.  5.102                                          libavfilter     4.  0.103 /  4.  0.103                                          libswscale      2.  5.101 /  2.  5.101                                          libswresample   0. 17.104 /  0. 17.104                                          libpostproc    52.  3.100 / 52.  3.100                                        Input #0, ogg, from '60 - The Man Who is Chosen for Victory.ogm':                 Duration: 00:25:42.88, start: 0.000000, bitrate: 1265 kb/s                        Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 640x480, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc                                                     Metadata:        TITLE           : [a4e]Rurouni_Kenshin_TV_60[divx5.1.1].ogm                   Stream #0:1(English): Audio: vorbis, 48000 Hz, stereo, fltp, 104 kb/s           Stream #0:2(Japanese): Audio: vorbis, 48000 Hz, stereo, fltp, 100 kb/s          Stream #0:3(English): Subtitle: text                                        [NULL @ 0490d700] Unable to find a suitable output format for '\'               \: Invalid argument        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>ffmpeg -i "61 - The Juppongatana Who Remain (aka The Choice for Life).ogm" \                         ffmpeg version N-59407-gfead241 Copyright (c) 2000-2013 the FFmpeg developers     built on Dec 28 2013 22:01:59 with gcc 4.8.2 (GCC)                              configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib              libavutil      52. 59.100 / 52. 59.100                                          libavcodec     55. 47.100 / 55. 47.100                                          libavformat    55. 22.100 / 55. 22.100                                          libavdevice    55.  5.102 / 55.  5.102                                          libavfilter     4.  0.103 /  4.  0.103                                          libswscale      2.  5.101 /  2.  5.101                                          libswresample   0. 17.104 /  0. 17.104                                          libpostproc    52.  3.100 / 52.  3.100                                        Input #0, ogg, from '61 - The Juppongatana Who Remain (aka The Choice for Life).ogm':        Duration: 00:25:41.02, start: 0.000000, bitrate: 1267 kb/s                        Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 640x480, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc                                                     Metadata:        TITLE           : [a4e]Rurouni_Kenshin_TV_61[divx5.1.1].ogm                   Stream #0:1(English): Audio: vorbis, 48000 Hz, stereo, fltp, 104 kb/s           Stream #0:2(Japanese): Audio: vorbis, 48000 Hz, stereo, fltp, 100 kb/s          Stream #0:3(English): Subtitle: text                                        [NULL @ 0033f7e0] Unable to find a suitable output format for '\'               \: Invalid argument        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>ffmpeg -i "62 - Kyoto, the Engraved Memory.ogm" \                                                    ffmpeg version N-59407-gfead241 Copyright (c) 2000-2013 the FFmpeg developers     built on Dec 28 2013 22:01:59 with gcc 4.8.2 (GCC)                              configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib              libavutil      52. 59.100 / 52. 59.100                                          libavcodec     55. 47.100 / 55. 47.100                                          libavformat    55. 22.100 / 55. 22.100                                          libavdevice    55.  5.102 / 55.  5.102                                          libavfilter     4.  0.103 /  4.  0.103                                          libswscale      2.  5.101 /  2.  5.101                                          libswresample   0. 17.104 /  0. 17.104                                          libpostproc    52.  3.100 / 52.  3.100                                        Input #0, ogg, from '62 - Kyoto, the Engraved Memory.ogm':                        Duration: 00:25:47.34, start: 0.000000, bitrate: 1264 kb/s                        Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 640x480, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc                                                     Metadata:        TITLE           : [a4e]Rurouni_Kenshin_TV_62[divx5.1.1].ogm                   Stream #0:1(English): Audio: vorbis, 48000 Hz, stereo, fltp, 104 kb/s           Stream #0:2(Japanese): Audio: vorbis, 48000 Hz, stereo, fltp, 100 kb/s          Stream #0:3(English): Subtitle: text                                        [NULL @ 0258ea80] Unable to find a suitable output format for '\'               \: Invalid argument        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>-map 0:0 -map 0:1 -map 0:2 -map 0:3 \        '-map' is not recognized as an internal or external command,                    operable program or batch file.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>-c:v copy \          The filename, directory name, or volume label syntax is incorrect.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>-c:a:0 libfaac -b:a:0 96k \        The filename, directory name, or volume label syntax is incorrect.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>-c:a:1 libfaac -b:a:1 96k \        The filename, directory name, or volume label syntax is incorrect.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>-c:s copy \          The filename, directory name, or volume label syntax is incorrect.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>"newfiles\%~na.mp4"  '"newfiles\%~na.mp4"' is not recognized as an internal or external command,     operable program or batch file.        F:\Videos\Anime\Rurouni Kenshin (1-95 Dual Audio)\Season 2>pause                Press any key to continue . . .
    I did as you asked and now I get 1 error:
    Unknown encoder 'libfaac'
    I follow the tutorial http://forum.videohelp.com/threads/356314-How-to-batch-convert-multiplex-any-files-with-ffmpeg so all I have is ffmpeg.exe and the bat file and the videos.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Remove the line breaks and \.
    pause
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Try with libvo_aacenc instead of libfaac
    Dec 2013
    Austin, TX
    Thanks, but still two errors remaining... it all has to do with the filename writing
    Could not write header for output file #0 (incorrect codec parameters ?): Error
    number -22 occurred
    And
    [mp4 @ 02617820] Could not find tag for codec text in stream #3, codec not curre
    ntly supported in container
    ^ I think I need to convert the subtitles?
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Try without any any batch first. Just one file. And see if you get any errors.
    And the subtitle stream copy might not work in a mp4 container.
    Dec 2013
    Austin, TX
    It's working away perfectly now.
    my final code is:
    for %%a in ("*.ogm") do ffmpeg -i "%%a" -map 0:0 -map 0:1 -map 0:2 -map 0:3 -c:v copy -c:a:0 libvo_aacenc -b:a:0 96k -c:a:1 libvo_aacenc -b:a:1 96k -c:s mov_text "newfiles\%%~na.mp4"
    pause
    I just had to specify:
    -c:s mov_text
    for conversion to mov_text from regular txt, a supported mp4 stream.
    Thank you so much.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Great!
