    Hi everyone i need some help
    I own a Avermedia H830 Hybrid Volar USB HD but the app seen to be crap.
    I install it without any error but the the app only show "Device is not ready" but i cant find anything which is not ready
    I also tried to use Windows Media Center but it dont allow Component setting as need what IR connection which i dont have.
    After tried now the Windows Media Center seen to give error and end task when everytime i want to scan for tv channel.
    SO i Need recommand to 3rd party Application that can Record from Component
  2. You must mean composite, as this device doesn't support component (YPbPr).
    I think it uses software encoding for the analog inputs, so try VirtualDub.
    yes sorry i mean composite.
    But this device come with composite plug. Cannot be dont support.
    I also tried the FM antenna that come with it.. cannot be use it.. not sure isit the app is having problem
