    Hey my new Xbox One has uncompressed 5.1 or 7.1 options for audio output. Isn't uncompressed better then DTS or Dolby digital since they are lossy/compressed formats? Is there an advantage that DTS or Dolby give you?
  2. Member netmask56's Avatar
    Depends on the input material - if it's DTS or AC3 only then how you output it isn't going to change the quality.
    TheVoiceIsAnotherPerson ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030
