I am currently producing a DVD of our Wedding from a VHS tape using a Canopus ADVC100 for capture and then TMPGEnc Plus to convert to MPEG2 for use in TMPGEnc authouring works to create the DVD and pretty menus etc etc. HOWEVER there is a background buzzing throughout the whole video (from source), which stands out, especially during the speeches etc etc.....
Is there any (EASY) way to either reduce or even filter out this noise from the filmeither by means of a filter imported into the conversion or one that can be applied to the raw capture.
I have tried to use the noise filtering component on the Authouring Works program but it seems to turn the audio into a metallic screech for the want of a better word, so I think that feature must only work when Authouring Works is used for the conversion AND the DVD production.
Can anyone help me out or as it is on the SOURCE VHS tape, it is something we weill have to live with
Filtering help needed
By x264 in forum RestorationReplies: 389Last Post: 30th Aug 2016, 10:31 -
Filtering
By x264 in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2013, 02:47 -
Need help filtering Jaggies
By LadyLiete in forum RestorationReplies: 12Last Post: 21st Aug 2012, 06:30 -
Filtering during MPEG capture
By TB Player in forum Capturing and VCRReplies: 9Last Post: 31st Dec 2010, 18:53 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57
