Results 1 to 14 of 14
  1. Member anon125's Avatar
    http://en.savefrom.net/1-how-to-download-youtube-video/
    i downloaded a video in mp4? but it was a bit blurry on the television.
    if the video was NOT posted that way... which is the best format to use when i download it.
    one format just had the file name with no extension when i downloaded it!
    what i downloaded http://www.youtube.com/watch?v=zmPzbZVUp3g
    thanks all
    the options
    FLV 240p
    MP4 360p
    MP4 720p
    WebM 360p
    3GP 144p
    3GP 240p
    MP4 480p
    MP4 1080p
    Audio MP4 48
    Audio MP4 128
  2. Member hech54's Avatar
    Originally Posted by anon125 View Post
    it was a bit blurry on the television..... the video was NOT posted that way
    That's because:
    1) The download can only be as good as what was uploaded. Many of these downloading programs offer quality options that are unobtainable because the original upload may have been a crappy WMV or FLV file to begin with.
    2) The video you are watching on YouTube is the size of a postage stamp compared to the size of your television. Depending on how long ago it was uploaded and WHAT was uploaded....you may never get good quality.
    3) Changing (downloading) programs will not help either.
  3. Originally Posted by anon125 View Post
    You download it in the highest resolution available, making sure your download program doesn't reencode it at the same time.
  4. Member anon125's Avatar
    obviously.
    YOU know which is the highest resolution available.
    most of us do NOT know that.
    which is the best one?
    thanks
  5. Originally Posted by anon125 View Post
    obviously.
    Obviously?
    I'd say most of us do know that already. Maybe everyone but you knows that already. The 1080p one. Or in words you might understand better, get the one with the highest number.
  6. Member anon125's Avatar
    neither of us know every one on this forum.
    i will give the 1080 a try.
    edit: self-deleted too mean
  8. Member anon125's Avatar
    well what happened is this. i now have a file called videoplayback with NO extension. how do i play it?
    thanks
  9. add an extension.
  10. Member anon125's Avatar
    tried ,avi and windows would not play it
    tried mp4 - same problem.
    what extension will give the best result?
    i downloaded it as mp41080
    thanks
    ps at 4.6gb it is too big to fit on a regular disc!
    Perhaps drag and drop onto mpc-hc or similar.
  12. Windows doesn't play media files. Media players do. Depending on which version of Windows you have, Windows Media Player may not support MP4 file unless you have an MP4 reader/splitter and the appropriate codecs installed.
  13. Member johns0's Avatar
    Also unhide your extensions so you can see what is.
  14. Member anon125's Avatar
    thanks all
