    I've been trying to play MKVs with a selection of audio tracks (is that the correct term?), regular soundtrack, directors commentary, 2nd language, that sort of thing) and cannot find a way to select the track.
    Ideally I would like to play USB to LG BP33 or MKV burned to BD, so I don't have to do any converting or authoring. When I play off the stick or BD audio and video are all good but I can't select the audio tracks, defaults to track 1. I know there are multiple tracks, can play them on PC using VLC. Docs have not been helpful.
    I am using LG BP33 converted to all region and Panasonic Viera 50" Plasma. Play sound through DAC to my stereo, but have the same issue when sound straight into screen. There is simply no menu that I have found to select tracks.
    Have you every watched your grandparents use an ATM? That is about where I am with this stuff. Been watching movies on my computer so long I am clueless about everything else. I want to avoid using my PC as a media server.
    Thanks in advance, sorry if this is a common problem.
    Install MediaInfo and open one of your problem MKV files with it. Post back here everything it says so we can see what format your audio tracks are in. There might be a problem with the audio being in an unsupported format or there's also a chance that this player simply doesn't support multiple audio tracks in MKV files and can only play the first one.
    Thanks, printout below. I think the commentary tracks are 3 and 4
    FYI -- the MKV has no menu, it is not authored in any way, just a stream starting with the start of the movie, ends with end of movie. As I said I can see the multiple tracks using VLC
    First list is the LGB33 specs for supported files, audio
    FileTypes:
    “.avi”, “.mpg”, “.mpeg”, “.mkv”, “.mp4”, “.asf”, “.m4v” (DRM free), “.vob”,
    “.3gp”, “.mov”, “.trp”, “.m2t”, “.mpe”, “.m1v”, “.m2v”, “.wm”
    Codecs
    XVID, MPEG1 SS, H.264/MPEG-4 AVC, MPEG2 PS, MPEG2 TS, VC-1 SM (WMV3)
    Audio Format
    Dolby Digital, DTS, MP3, WMA, AAC, AC3
    MEDIAINFO Printout
    General
    Unique ID : xxxxxxxxxxxxxxxx
    Complete name : G:\dvds\MOVIE_TITLE_Bluray.1080p.DTS.x264-Grym@BTNET.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 10.2 GiB
    Duration : 1h 23mn
    Overall bit rate : 17.5 Mbps
    Encoded date : UTC 2013-10-17 08:33:39
    Writing application : mkvmerge v6.4.1 ('Omega Point') built on Sep 16 2013 22:05:10
    Writing library : libebml v1.3.0 + libmatroska v1.4.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 23mn
    Bit rate mode : Variable
    Nominal bit rate : 14.0 Mbps
    Maximum bit rate : 30.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.282
    Writing library : x264 core 138 r2358 9e941d1
    Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 /
    mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 /
    lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=0
    / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 /
    rc=2pass / mbtree=1 / bitrate=14020 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=30000 /
    vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.10 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 1h 23mn
    Bit rate mode : Constant
    Bit rate : 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 900 MiB (9%)
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    Format : PCM
    Codec ID : A_PCM/INT/LIT
    Duration : 1h 23mn
    Channel(s) : 2 channels
    Bit depth : 16 bits
    Language : English
    Default : No
    Forced : No
    Audio #3
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 23mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Stream size : 115 MiB (1%)
    Language : English
    Default : No
    Forced : No
    Audio #4
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1h 23mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Language : English
    Default : No
    Forced : No
    Text #1
    Format : PGS
    Codec ID : S_HDMV/PGS
    Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
    Language : English
    Default : No
    Forced : No
    Text #2
    Format : PGS
    Language : Spanish
    Default : No
    Forced : No
    Text #3
    Format : PGS
    Language : Chinese
    Default : No
    Forced : No
    Text #4
    Format : PGS
    Language : Chinese
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:00:00:00.000
    00:03:31.044 : en:00:03:31.044
    00:10:32.298 : en:00:10:32.298
    00:18:44.998 : en:00:18:44.998
    00:24:06.862 : en:00:24:06.862
    00:30:24.239 : en:00:30:24.239
    00:40:22.044 : en:00:40:22.044
    00:47:04.238 : en:00:47:04.238
    00:58:02.896 : en:00:58:02.896
    01:04:05.007 : en:01:04:05.007
    01:11:21.694 : en:01:11:21.694
    01:18:45.178 : en:01:18:45.178
    01:21:56.328 : en:01:21:56.328
    01:23:24.416 : en:01:23:24.416
