Hey everyone,
I can't seem to get the correct setting to convert a VOB to avi and retain the Audio Track I want.
It seems to only be on ONE VOB file that selects track 1 as the default track.
Any help would be greatly appreciated.
It would be much easier to use DVD Shrink to cut the section you want and then convert to avi.
Hopefully you can isolate the audio track you need. -
So you don't have the original DVD, I guess.
Take a look a look below on how to quickly author new IFO files. Once you have these you effectively have a new DVD structure to work with and Shrink should be able to load and trim it.
http://forum.doom9.org/showthread.php?t=99342
DGIndex might prove useful to you also -
Or try remove one audio track with tsmuxer, output as a new ts file that you convert with format factory.
Default Audio selecting the wrong track!
By pluton in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 26th Jan 2013, 03:30 -
Adding 2nd audio track to specific location...
By tweeker404 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2011, 23:53 -
Converting video to specific format, so hardware will decode
By numnum in forum Video ConversionReplies: 5Last Post: 11th Sep 2011, 15:23 -
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
selecting audio track
By july in forum AudioReplies: 0Last Post: 9th Jan 2009, 15:13
