I recently got a Hauppauge 1212 pvr. My goal is to trim and convert the .ts files produced by the device into smaller dvd quality m4v files to use with Plex media server on a Roku 2 LT.
I have successfully trimmed the files with Avidemux, converted them to DVD compatible mpeg2 with WinFF, and created DVDs with DVDAuthorGUI. These have very good quality, but my problem is with converting either the raw files, or the DVD mpeg 2 files to m4V with either ffmpeg or handbrake.
When I convert to either 480p or 720p from either raw files or MPEG, I resize, deinterlace, and set cbr to 29.97 fps with ac3 pass through at q=17. These are the same settings that I have used before with good quality encodes, but for some reason, when I encode these files they are of significantly lower quality than the DVD mpeg2 files.
Does anyone have advice on how to successfully convert to what I want to do?
VHS conversion problems
By flei in forum Newbie / General discussionsReplies: 4Last Post: 30th May 2013, 08:06 -
Pixelation Problems after conversion
By JaneHarris in forum Newbie / General discussionsReplies: 9Last Post: 24th Oct 2012, 15:00 -
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 06:22 -
AGK conversion problems
By loninappleton in forum SubtitleReplies: 10Last Post: 9th Sep 2009, 10:48 -
Having problems with mkv conversion
By twiadpaws in forum Blu-ray RippingReplies: 0Last Post: 4th Mar 2009, 13:31
