    Dec 2013
    France
    Hello,
    I want to convert a old video mpg to mp4.
    However the whole video has a default vertical and horizontal lines. See attached examples.
    Is it possible to remove them with a plugin for VirtualDub? Or other tool ?
Name:	Title_2.mpg.Image fixe004.png
ID:	22321Click image for larger version
Name:	Title_2.mpg.Image fixe002.png
ID:	22324Click image for larger version
Name:	Title_2.mpg.Image fixe001.png
ID:	22322Click image for larger version
Name:	Title_2.mpg.Image fixe003.png
    Thank you for your answers.
    Wallis.
  2. I removed something similar a few years back using avisynth (see: german doom9 forum)....
    Dec 2013
    France
    Thank you for your answer, I'll see it all.
  4. Try DeStripe():
    http://forum.doom9.org/showthread.php?p=1408276#post1408276
    It does blur the picture a bit. Before/after:
    DeStripe(last, rad=5, thr=100)
    You can go with weaker settings but then you get less effective removal of the stripes. If the lines aren't static you can probably use a mild DeStripe() followed by a temporal noise filter like McTemporalDenoise().
    If you post a video sample some of the usual suspects around here will probably give you some more specific guidance.
